Question about Magellan Maestro 4250 GPS
Software update There are a lot of local streets not showing up on my GPS so where do I find map updates for the Maestro 4250?
  • 214 Answers
Here's a link to the website for your unit. If you click on the 3rd line under "facts" it will take you to a page where you can register to receive map updates. Good luck. If this helps you plz rate this. Thank you kindly.
http://www.magellangps.com/support/product.asp?prodid=1958
Posted on Jan 31, 2009
Hey I want to updating maps or software for magellan maestro 4250, but i can not found the right software for it,so pleas can you help me,thank you.
Hi muntaserabou
you can get the latest firmware 4.86 for your 4250 HERE and the
2010 Map update for it HERE
Nov 27, 2010 | Magellan Maestro 4250 GPS
When i put in ad address it says the gps needs to be updated and restarted . what do i do ?
the address is not found in the memory because the map software is out of date, that is what the message means
Jul 23, 2010 | Magellan Maestro 4250 GPS
Screen says: USB connected The USB has been
If your trying to update your 4250, you can go here to get the latest update, which is 4.86
you will have to register the unit on the magellan site before you can download the update.
just make sure you follow the directions for the update exactly as it says!
if you need further help, id be glad to help you.
Jul 22, 2009 | Magellan Maestro 4250 Car GPS Receiver
Our Magellan Maestro 4250, came on by itself and will not turn off.
is it plugged to AC charge when it comes on?
If not seek out the RESET hole and place a fine pin or paper clip end in and reset the unit
Jun 20, 2009 | Magellan Maestro 4250 GPS
Magellan Maestro 4250 2008/2009 Map Update will not update my GPS
I also had problems with a refurbished Magellan 4250. The paperwork inside said to install the 4.85 firmware update which I found would not work with Windows XP Home at least for me. I used my laptop which has Vista Ult 32 bit it updated with no problem that is so far the only solution I used.
Apr 21, 2009 | Magellan Maestro 4250 GPS
Maestro 4250 frozen after incomplete 2009 map up date
I had same problem on 3/28/09.
According to Magellan and other people who have experienced the same problem, this is terminal to the unit. It can be caused by downloading the 08/09 Magellan map upgrade, which can cause the unit to permanently lock up. Magellan is well aware of the problem, and should offer to replace your unit if you have the problem. If you elect to have it repaired, Magellan can download the map upgrade for you in the repair process. Here is a site noting the same problem: http://74.125.93.104/search?q=cache:pNLjGT-i4-sJ:forums.gpsreview.net/viewtopic.php%3Ft%3D8958+magellan+4250+gps+stays+on+blue+screen&cd=8&hl=en&ct=clnk&gl=us
Questions for Magellan: 1) why would they sell, in 2009, gps units with old 2007 maps loaded in them, requiring the purchaser to buy a current map, and 2) if there is a problem with downloading the current maps, why is there not an advisement or warning to the installer.
Other than replacing the unit, there appears to be no "fix".
Mar 29, 2009 | Magellan Maestro 4250 GPS
There is a RESET button on the bottom of the unit on the left side
Nov 22, 2008 | Magellan Maestro 4040 GPS Receiver
Map update error problem with Magellan 4250
I had the same problem until I plugged the usb cable into the back port of my computer. Then it worked. Something about using a higher speed usb port.
Oct 23, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 4040 or 4250 going to europe
I bought a Garmin 750 on compusa website for 230 and it supports European maps
May 12, 2008 | Magellan Maestro 4040 GPS Receiver
Maestro 4250
Maestro 4250 is frozen. HELP ;-(
Dec 26, 2007 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 GPS Logo
170 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
