Question about Baumatic 20 in. BWK1 Gas Cooktop
Changing gas jets on an Ilve H60cv gas cooker
I have recently purchased an Ilve H60v gas cook top however the jets in the unit are for mains gas. I have LPG bottles. I have purchased the appropriate gas Jets for LPG but do not know how to instal them or where to find a manual which will give me the information.
    Problem Solver:
  • 5 Answers
Contact appliance manufacter
Posted on Jan 01, 2010
One of the control knobs that ignites the burner is not working on gas cook top
First check the burner jet , nine times out of ten it will be blocked, probe it with primus pick or fine needle with the gas on, this will blow out any muck.
Jul 02, 2015 | Cooktops
Plumber is installing my new wolf cook top - electrician coming tomorrow to connect the power - plumber cant make gas come through the jets - what is wrong
Did the plumber make sure there was not something plugging the gas service connection on the range before he hooked up the gas pipe from the house to it?
Mar 16, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Wiring with 2 wires out of wall
try to use black to black: white to red: and green and white to ground.
you may not have a 240 volt supply to this unit. most of the time when you have these color wires that would tell me that it only has 120 volts of power.
you can try to wire it up as described, but it may not heat enough with just 120 volts.
what type of cook top did you replace, a gas unit and now your changing it to an electric one?
if so, then you will have to replace the wiring inside the wall with the proper size wiring to handle the extra current from an electric unit.
Jan 12, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
I want to switch my 5 burner kleenmaid CH80x8 natural gas cooking top over to LPG what size jets or injectors do I need. Regards James. Centre burner is for a wok current jets are 50. 78. 85. 62. 95
LPG to natural, natural is bigger than LPG injector exmaple LPG 50=natural 69-
LPG 78=natural 91
LPG 85=natural 115
LPG95=natural 130
PLG 62=natural 85
Sep 09, 2009 | Cooktops
No wattage given with electrical requirements for gas cook top
A gas range requires minimal electric current. "Any ole" circuit will do.
Charlie
May 13, 2009 | Jenn-Air JGC8430 Gas Cooktop
Clicking gas cook top
I accidentally bumped the thing where the gas comes out (I don't know what it's called - I'm a wife not a tekkie) and it started clicking when I turned it on. I turned off the gas and repositioned that gizmo and it stopped clicking.
Feb 19, 2009 | Thermador SGS36GS Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Baumatic 20 in. BWK1 Gas Cooktop Logo
570 people viewed this question
Top Baumatic Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
