Question about Kodak EASYSHARE 5100 All-In-One Printer
Printhead failure error code 3802
My easyshare 5100 keeps coming up with code 3802. print head failure. have only had the printer about a month. and has hardly been used because of this problem
  • Anonymous Mar 25, 2014
    repeatedly asked to disconnect and replace the printhead
  • 315 Answers
You need to contact kodak and ask for a replacement print head, explain the code and whats been happening.
www.kodak.co.uk
They will probably tell you to download new drivers and wash your printhead ect ect but nothing that helps.
I had the same problem with the same printer.
I couldn't get Kodak to send out a printhead, so after weeks of messing around, I took it back for a refund.
If you do manage to get a new printhead here are the instructions on how to remove and replace it.
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Posted on Jan 31, 2009
Why will my printer not print. shows error 3802. just prints blank page. do have ink.
Error: "Printhead Failure" (105-3802) - Kodak
support.en.kodak.com/.../error%3A-printhead-failure-(105-3802)
KodakAug 25, 2010 - How do I resolve the error message "Printhead Failure" (error code ...If you are not prompted to calibrate the printhead, turn off the printer, wait ...
Error: "Printhead is missing, not installed correctly, or has ...
support.en.kodak.com/.../error%3A-printhead-is-missing,-not-inst...
KodakAug 25, 2010 - How do I resolve the error message "Printhead is missing, not installed correctly, or has come loose" (error code 105-3513) on my ESP or HERO All-in-OnePrinter? ... If the printhead and ink cartridges are not installed in the printer, install them: ... If the error continues, restart the printer and try to print.
Jan 18, 2016 | Kodak ESP5 AllInOne InkJet Printer
Getting problem code 3802
Hello thanks for using Fixya
Error 3802 Mean Print head Failure
Turn the printer Off and On, This problem is solved by this mostly.If the problem still there then remove the ink cartridges and the print head and after few minutes put it back in the printer .If the problem still there then do it again almost five times & if still problem not solver and you get error code 3802
then it is probably that your KODAK Esp 3250 Allinone Multifunction Printer is in need of servicing by a service professional.
So go to the KODAK Service Center
Your problem will be solved.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation "if it is helpful"
THANKS
Keep Using Fixya
Feb 28, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Getting a print error 3802, just installed printer today. As soon as we changed quality to best, got error code.
Hi. Error means your printer failed to communicate with the printhead. If issue is not resolved by turning the printer off/on then you need to buy a new printhead. Here's a link on how to install a new printhead.
Oct 11, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak ESP5 Error Code 3802 and will not print yellow even with cleaning and new ink.
Issue is with printhead
visit www.kodak.com/go/itg
Select all-in-one printer
Select image quality > missing color > follow the steps to order a free printhead
Else
call 18004216699
Dec 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
What is error code 3802
"Printhead Failure" (error code 3802)
To resolve this error:
  1. Open the printer access door.
  2. Disconnect the power adapter from the printer.
  3. Remove and install the printhead two times.
  4. Wait 30 seconds to allow the printer to reset.
  5. Connect the power adapter to the printer. Turn the printer on if necessary.
    • After the printer completes powering up, the message "Printer access door open" will appear.
  6. Close the printer access door.
If error condition continues, contact Kodak for printhead replacement.
Best of Luck
Nov 17, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
I have a kodak aio esp07 printer. I'm getting a 3802 error - what is this?
To resolve the error condition:
  1. Open the Printer Access Door.
  2. Remove and install the Printhead two times before closing the Printer Access Door.
  3. Wait until the printer is ready to use.
  4. Close the Printer Access Door.
If the error condition continues, contact Kodak.
Jul 14, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 all in one printer, 3802 code
www.kodak.co.uk or www.kodak.com
Jan 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Error 3802
printer can not talk to printhead... power off. wait. power on
Sep 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300 first said error 3802 now says print head missing or loose
I got the same Problem as listed above. This is the way how I was able to solve it:
  • Remove the color and black ink cartridges and the printhead. (the 5300 Printhead can be removed by pressing a button on top of the carriage and a slight pull --> for better instructions use this official Kodak PDF)
  • Try to clean the printhead and the carriage with a slighty wet cloth from ink. CAUTION!: better not touch the green electronic chip! Be carefull while cleaning.
  • Reinstall the printhead and the ink cartridges.
  • If the printer detects a 'new' printhead just do a calibration and your are done. If not try to print a test page.
Hope this solves the Problem. Best wishes
May 20, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
316 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
