Question about Yamaha DVD-S540 DVD Player
No picture I was in the set up menus and inadvertently set the TV from NTSC to PAL the screen went blank. Now I cant see the menus to get it back to NTSC. (not well thought out...) I am connected via Yamaha RX-V 2700, component input upconverted to HDMI output
  • 2,071 Answers
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Posted on Jan 31, 2009
My Disney lightning McQueen tv wont play dvds in color. The cable plays in color just fine. I think my son changed the settings some how, I've went through the book front to back and the setting...
go to settings for playback/ video and check to see if it is NTSC or pal.whatever it is switch it to the othe and the colour display should then be correct.europe is pal. America is NTSC.
Oct 27, 2014 | Disney CARS 14 TV/DVD Combo
Please help
Have you try: NTSC on PAL TV On • NTSC discs will play correctly on PAL-only TVs.
Off Use if your TV is already NTSC-compatible.
Many recent PAL TVs are compatible with NTSC input and so this setting can be switched off. Check the operating
instructions that came with your TV. See also About NTSC on PAL TV on page 124 for related information.
Sep 14, 2008 | Televison & Video
The picture is only black and white and is flashing on my computer screen. Sound is good.
Usually, this indicates that video source is PAL but the capture is set to NTSC, or that the video source is NTSC but the source is PAL.
Make sure that the video capture device is set to match the signal of the input.
PAL is used in Europe, NTSC in North America.
How you set it depends on the Video Capture software you use, but look for PAL/NTSC setting and switch it.
Apr 18, 2011 | Diamond Multimedia ( VC500) Video Capture
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
Using pal/ntsc system dvd player in USA - how to setup to work on ntsc tv
You sould have a button on the remote controls thats says Pal/NTSC, press that button to switch.
Nov 07, 2008 | Durabrand Televison & Video
When I try to play PAL tapes, there is no picture
You also need a PAL television or monitor to be able to view them. If you don't have a PAL compatible monitor or TV it will not work because the resolution and scanning is very different than an NTSC monitor. Your canon camera is probably designed only for NTSC use if it was sold in North America and can't be used for PAL use.
Jul 31, 2008 | Sony DSR-11 DV / Mini DV VCR
How to reset dvd recorder to ntsc from pal
After checking today to see no one offered any suggestions - I solved the problem the hard way - I went into settings and although the screen rolled, I was finally able to click onto the ntsc setting after about a half hour of tries and once I clicked it, my screen returned to normal -- i was then able to enter the code that made the player an all region player and was happily able to play a pal dvd I received recently. The procedure was simple -- offered by a European Cyberhome user -- the company is in bankruptcy so you cannot gt help from them. Note - my Cyberhome dvr is 1500- not 1600 as you listed it.
Feb 11, 2008 | Cyberhome DVD Recorder - DVR1600
Black and white picture i did switch my setting to the pal by accident
set the palsecam or ntsc mode! or you have defective board video drive!
Oct 02, 2007 | TruTech TT1620 DVD Recorder
Lifestyle 38
Its very simple just press the "pal" button again until you see the "pal" icon comes up
Sep 16, 2007 | Bose Lifestyle 28 System
Oritron no picture
Phase Alternating Line (PAL) is a colour encoding system for analogue television used in broadcasttelevision systems in most countries broadcasting at 625-line / 50 field (25 frame) per second (576i)
NTSC is the video system or standard used in North America and most of South America. In NTSC, 30 frames are transmitted each second. Each frame is made up of 525 individual scan lines.
You might try disconnecting all power from the system. unplug it.
disconnect the TV. Power back up. Maybe it will reset to factory settings. See if your TV will have a switch to NTSC.
Oct 04, 2017 | Oritron Televison & Video
Yamaha DVD-S540 DVD Player Logo
285 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
