Question about Emerson MS9700 CD Shelf System
My ms9700 plays 2,4,and 6 disc not 1 , 3 , 5 - Emerson MS9700 CD Shelf System
Cd stereo says no disc
The player mechanism may have failed.
Sep 08, 2014 | Emerson EM-MS9700 6 CD-Changer stereo...
Tip
Xbox help for "Can read CD but NOT DVD."
Step 1: Inspect and clean your disc Take a close look at the bottom side of your game, movie, or music disc (the side without a label or image). Are there scratches? Excessive scratches or smudges can prevent your console from reading the disc. Clean your disc 1. Hold the disc by the edges without touching the top or bottom surfaces. 2. Using a soft, clean, slightly damp cloth, lightly wipe from the center of the disc outward. Note Do not use solvents to clean the disc. 3. Once the disc is clean, load the disc into your console and see if the disc plays. If the disc still does not play, try step 2. Step 2: Try other discs Try other discs to determine whether the problem happens with any disc or only with this particular disc. If multiple game discs, DVDs, or CDs will not play: 1. Make sure the media type and the disc region code are compatible with the console. 2. If the problem happens with several discs of different types (games, DVDs, and CDs), skip to “Step 7: Request a repair” below. If a specific game disc will not play: 1. Search the Microsoft Knowledge Base to determine if the game title has any known problems. 2. Make sure the media type and the disc region code are compatible with the console. If the disc you are using has a region code that is compatible with your console but you still cannot play the disc, try step 3. Step 3: Clear your system cache If your Xbox 360 console can’t play multiple game discs, try clearing your system cache. Here’s how: 1. On the console, go to My Xbox, and then select System Settings. 2. Select Memory. 3. Highlight any storage device, and then press Y on your controller. 4. Select Clear System Cache.
Note If Clear System Cache is not available, use the button sequence described in the following article: 971755 How to clear the Xbox 360 console cache 5. Try to play a game disc. If you still can’t play a game disc, try step 4. Step 4: Remove the hard drive If the problem only happens with game discs, let’s try temporarily removing your hard drive. If your Xbox 360 console does not have a hard drive, skip to step 5. 1. Turn off your console. 2. Locate the hard drive on your console. 3. Press the release button on the hard drive and lift the hard drive from the console. 4. Turn on your console. 5. Try to play a game disc.If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If this step resolves the problem, reattach the hard drive and contact Xbox support to order a replacement hard drive. If you still can’t play game discs, try step 5. Step 5: Disconnect memory units 1. Turn off your console. 2. Unplug any memory units attached to your console. 3. Turn on your console. 4. Try playing a game. If this step resolves the problem, reattach the memory units and contact Xbox support to order a replacement memory unit.
on Feb 15, 2010 | Video Game Consoles & Games
Change radio frequency to infrared frequency for the emerson MS9700
I very much doubt your Emerson unit uses radio frequency for remote control
Nov 25, 2012 | Emerson EM-MS9700 6 CD-Changer stereo...
Everything works on my emerson MS9700 except the cd player. the display keeps saying no rdy. how can i fix this?
If the indication says" not ready " it means that the disc is not reading the data present on it . It is possible that the disc is not scanned by the optical head to be ready to play.
So it is possible that the optical head is defective or weak, please try to clean the optical eye with ear bud very softly or use a disc cleaner.
If there is no result the head can be faulty.
If the set was not used for long time please keep it powered ON.
Also the processing section/main board can be a suspect.
Nov 19, 2010 | Emerson EM-MS9700 6 CD-Changer stereo...
MY EMERSON MS9700 READS NO READY WHEN I TRY TO PLAY A CD.. IT TURNS THE CD MAKES THE SQUEAKING NOISE LIKE ITS READING IT BUT THEN NOTHING HAPPENS OTHER THAN THE NO RDY MESSAGE.. HOW CAN I FIX THIS???
I've been having similar problems. I've had mine over 4 years, so it is likely on its last leg. To resolve, nothing techno here, I take both hand an simultaneously give the entire unit a good "bang" on both sides. Sometimes it takes 2-3 attempts, but so far it has been working. I'm already on the look out for a new system, as i know this probably won't work forever.
Sep 12, 2010 | Emerson MS9700 CD Shelf System
My 360 only plays cds or dvd s wont play games please advise
Feb 15, 2010 | Microsoft Xbox 360 Console
Emerson ms9700
one thing that you can do and this helped me when i had that same problem is to take off the top cover and clean the laser lens
Oct 25, 2008 | Emerson MS9700 CD Shelf System
Cd jumps tracks
The CD lens may need cleaning.
Try a 'wet' CD lens cleaner.
The laser PU may be low emision.
Nov 09, 2007 | Emerson MS9700 CD Shelf System
MS9700 secondary voltage
This product is designed to operate on normal 120V 60Hz AC only.
Nov 18, 2005 | Emerson MS9700 CD Shelf System
Emerson MS9700 CD Shelf System Logo
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
