Question about Panasonic DMR-E85H DVD Recorder
Recorder self-check... after inserting a disc.
It continues self - checking for ages ... until i pull the plug, out of frustration! does not respond to anything, such as power on/off, door open/close ... NOTHING!
  • 2 more comments
  • islandzac Feb 01, 2009
    pulling the main power cord, and keeping it off for 2hours, has stopped my recorder from self-check ... unfortunatly, everytime a disc is inserted ... the problem comes back again! the home movies i played use to be able to playback, and now they will not! any disc now inserted (including ones from the video store) will send my recorder in self-check mode!
  • Scampston Feb 28, 2009
    Same. It starts repeating self check when a disc (blank or pre-recorded) is inserted. Never used to happen!
    Charles Legard
    Charles@scampston.co.uk
  • sfstan Mar 02, 2009
    i have the same problem with self-check when i insert a blank dvd. i have had the unit for 4 years and has operated flawlessly once the u99 code was fixed. i am using white printable sony blank dvds. the problem happens maybe 1 out of 6-10 insertions of a blank dvd. possibly the alignment of the heads are a little off? i have been using this brand of dvd for years and only have this problem the last few months.
  • timross Apr 12, 2009
    I have the same problem. Has worked fine for 3 years, playing any disc I put in, pre recorded or home recorded, now it just self checks all the time. It works fine just recording and playing back off the hard disc only.
Inserting a disk OTHER than Panasonic will cause a system crash. I'm betting Panasonic has code that causes this so you don't use cheaper generic DVDs. I now have to mail order the Panasonic DVDs (since nobody carries them) and have never had a crash since!
Posted on Feb 25, 2009
I have recently developed a problem with my vr320.When I insert a new disc or a downloaded DVD it takes ages to load and then displays "The disc can neither be played or recorded Please check disc" Yet it...
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! Unplugg before opening!
Oct 12, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
DVD+R stuck in logik ldvr808 recorder
Pull out the power cable and leave for a few minutes then plug it back in. Now before the DVD player tries to play the disk press EJECT or OPEN/CLOSE button continously until it releases the disk.
Jul 10, 2009 | Televison & Video
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Cheers...
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
PANASONIC DVD RECORDER STUCK ON SELF CHECK
This can usually be down to two things, a faulty PSU board which is going to be expensive and needs to be professionally repaired, or simply a faulty or dirty DVD has been inserted into the machine.
Try the following:
1. Hold down Standby and Eject buttons on front panel together for 60 seconds (until the recorder goes into standby mode).
2. Now hold down Eject button until it ejects the disc.
3. Now insert a different DVD disc and see if that cures the problem.
If that fails then it's probably a faulty PSU, and unless the recorder is under guarantee or warranty it will be too costly to repair.
Jun 30, 2008 | Televison & Video
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Model No'DMR-ES15 - U61problem
no comunication betwen control y dvd
May 11, 2008 | Panasonic DMR-EZ27K
Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
Panasonic DMR-E85H DVD Recorder Logo
238 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
