My monitor has powered down and wont come back on. What do I do to get back up running?
    Novelist:
    Scholar:
  • 72 Answers
Have you tried unplugging all cables, then plugging them back in securely? If that does not work, your monitor may have failed.
If you have another monitor, check your computer with the other monitor to see if the problem is really your computer.
Posted on Feb 11, 2009
My screen wont turn off
Press and hold the power button on the monitor until it turns off. If you press and hold the button for more then 2 minutes or so and get no response, unplug it from the power source. Then press and hold the power button down for 60 seconds while it is unplugged. then plug it back in and turn it on. that should solve your problem.
Jul 13, 2011 | HP 2009M Monitor
Wont start up
Check physical connections first, check monitor cable if securely plugged in and then check power light of monitor. If power light on monitor is amber or yellow it means that monitor is not getting a signal from cpu/ tower. Try to do a power drain on the computer, remove power cable at the back of the computer and then press and hold the power button for 10 secs, after that plug in power cable again and restart the computer.Check if there is any connection if not then try to use another monitor, a known good one. If you get a video from another monitor it means monitor is already defective.
May 15, 2010 | HP Pavilion a1610n PC Desktop
Monitor wont power back on, Tried almost everything. Some days it will power up , sometimes is wont. If my timing is perfect and I plug the monitor into power cord at exact time I turn on computer it will...
Hello Adam,
You have a monitor with a power supply that is failing. The most likely cause is capacitors on the power supply board. We have an article posted on our site at: http://www.ccl-la.com/blog/index.php/capacitors/ That explains what they are and what you need to get to repair the board. If you don't want to do the repair yourself then we do offer a repair service, more information on this can be found at:http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions please contact us thru our web site.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Mar 14, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Monitor times out and wont come back on.
Try this settings:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Aug 03, 2009 | Acer AL1914 19" LCD Monitor
    On button is orange and moniter wont come on
    If the PC is on and running and the light is oragne it means your video card is bad or the cable is loose.
    Power off your PC (gonna have to hold the button down on PC until it turns off) and then turn off the monitor.
    Reseat cables on both ends from Monitor and PC then power back on again and see if that helps.
    If it still doesn't work you have a bad video card.
    Hope this helps
    TankMurdock
    Apr 24, 2009 | X2Gen MG19VT 19" LCD Monitor
    1of 2 monitors wont turn on
    Frostbane is correct. I called 1-800-SAMSUNG to report the same problem and they are going to send me a replacement display.
    Mar 24, 2009 | Samsung 226BW Monitor
    Hi need some help with 17" philips crt comes on runs until windows start then switch of all power wont come back on for 15min restart pc then screen display out of frequency range, set frequency range down...
    You can try starting your computer in safe mode and restore your computer to another safe point. usually this problem is caused by an update or a new driver installation/update...
    Mar 08, 2009 | LG Studioworks 775N 17" CRT Monitor
    Computers & Internet Logo
    26 people viewed this question
    David Payne
    David Payne
