Dell DJ MP3 Player
Problem for Dell DJ MP3 Player
Dell Digital Jukebox and Vista
By Midlman on Jul 30, 2007
How do I get my dj 20 to with vista
Clarification Request
Posted by blueslover09 on Nov 01, 2009
I've downloaded three drivers from Dell, My Dell JB 15 still won't install. Any other ideas?
Posted by hapiduffer on Mar 06, 2008
McJunken
Can you tell me how to direct Vista to go to the downloaded driver? I can't get past the auto direct to the Web (microsoft).
thanks,
Same Problem
Apr 26, 2009
-   precisso do dirver para widows vista para poder usar o dell de 15 gb-   Guest
Apr 12, 2009
-   windows vista will not recogonze the driver for my Dell Digital Jukebox 20G. I belive it to be a generatiopn 1.-   billsaulsman
Mar 10, 2009
-   vista will not recognize driver
-   Guest
Jan 28, 2009
-   yeah, i cant find it at all -   Guest
Dec 29, 2008
-   Unable to connect Dell Pocket DJ to Windows Vista.
-   Guest
Best Solution
posted on Aug 20, 2007
Very Helpful)
lpstar
Rank: Wiz
Rating: 84%, 58 votes
Dell did not update the driver needed for the DJ. I have a 20Gb that can't be used in vista till they decide to or get around to the driver needed. They will let me know when it's ready.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 08, 2008
Very Helpful)
angel2152
Rank: Apprentice
Rating: 96%, 7 votes
just run the driver from the dell website, open the folder you extracted it in and run the setup.exe file with xp compatibility (compatibility tab in properties) and run it as an admin.
♠AnGeL♠
Was this helpful?
Yes
No
Solution #3
posted on Oct 17, 2007
Very Helpful)
Guest
Rank: Apprentice  MP3 Players  Expert
Rating: 0%, 0 votes
Just tried my DJ 30GB on Vista, worked fine.
I have the firmware version 2.20.07.
Solution #4
posted on Feb 29, 2008
Helpful)
mcjunken
Rank: Apprentice
Rating: 92%, 26 votes
In case there are still people like me out there who are having trouble getting Dell DJ to work with Vista, here's what worked for me: I went to the Dell.com support page for Dell DJ Gen 2 and downloaded this driver: 1.02.03 Driver for Dell DJ (Gen 2) / Pocket DJ. It downloaded as R88925.exe. Once I ran that executable and then ran setup from its destination folder, I connected the Dell DJ and had to direct Vista to look for the driver in C:/Program Files/Dell/Digital Jukebox Drivers. After that, it worked fine.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on Sep 10, 2007
Somewhat Helpful)
Guest
Rating: 0%, 0 votes
Um I have Visa and a Dell DJ 30GB....installed no problems. Try getting any Vista updates and try the site again...again mine is working on Vista with no problems.
Solution #6
posted on Jul 30, 2007
Somewhat Helpful)
frit
Rank: Wiz  MP3 Players  Expert
Rating: 84%, 186 votes
most likely you need to upgrade the firmware for your device. go to the dell website and find support software for your player. download the new firmware and install it.
Was this helpful?
Yes
No
Solution #7
posted on May 08, 2009
Helpful)
Doo-Dah
Rank: Apprentice
Rating: 83%, 6 votes
I'm not sure if this will help all your issues but I bought a Dell Digital Jukebox and found that Vista did not support this item. Most USB items are plug and play but every time I tried to install the softwaretthat came with it, it would get to about 91% and freeze up.
OK, the solution. One thing I've found with Vista is that it will support a lot of things that will not load. You need to go to properties and select, "Run as Administrator". What I did for this problem is I went to Dell.com, typed in my Jukebox ID #, located the Windows XP driver for my Jukebox and downloaded it. Then before I ran the setup I right clicked on the icon, went to properties and selected run as administrator. Wah-la, this did the trick. It loaded the software and I'm off to the races. I was able to upload music and manage my files.
I hope this helps your issue.
Was this helpful?
Yes
No
Solution #8
posted on Jan 08, 2009
Somewhat Helpful)
RawG
Rank: Apprentice
Rating: 75%, 1 votes
For DJ, we need to update the firmware for playforsure.
R107735.EXE
Files given next the DJ.
Firmware update will only happen in Windows XP.
Once the firmware update if finished on XP, then DJ will work on Vista , and there will be Removable Drive Icon in my computer as soon as DJ is connected in Vista.
Please not that Music match 9 will not work with DJ anymore after this update, cx need to use Windows Media Player 10 or above.
Here is the procedure to sync DJ with WMP11.
Sync Your Digital media to a Portable Device.
Set Up Your Device
When you connect a device for the first time, the Player selects the sync method (automatic or manual) that works best for your device:
  • Automatic. If your device's storage capacity is more than 4 gigabytes (GB) and your entire library can fit on the device, the Player automatically syncs your entire library. You can also choose what syncs automatically by selecting the playlists you want to sync. With this option, the Player syncs your digital media files to the device to mirror your library when you connect it to your computer or when you change sync settings.
  • Manual. With this option, you pick specific files or playlists you want to sync each time you want to make changes to the digital media files on your device, and you manually remove files from your device.
    After your device is set up the first time, if you want to, you can switch between automatic and manual sync.
    To set up a device
  1. Start the Player, turn on your device, and then connect your device to your computer. If prompted, select the option to sync the device using Windows Media Player.
  2. Do one of the following:
    • If the Player has selected to sync your device automatically, click Finish. When you do so, the Player will sync your entire library to your device. After that, your device will sync every time you connect it to your computer.
    • If the Player has selected to sync your device manually, click Finish. Then, in the Sync tab, you must select the files and playlists you want to sync manually.
Was this helpful?
Yes
No
Solution #9
posted on Aug 12, 2008
Somewhat Helpful)
SyCo123
Rank: Apprentice
When you can't connect the device to the PC how can you update the firmware?
The most hassle free solution is of course, don't use Vista. I now use Ubuntu Linux exclusively on my HP laptop (over one year now) and hate using Windows these days
here's a simple how to for Ubuntu users
http://w.holeso.me/2008/08/the-day-i-switched-from-vista-x64-to-ubuntu-for-compatibility-reasons/
And the short answer
sudo apt-get install gnomad2
Job done!
Was this helpful?
Yes
No
Solution #10
posted on Jan 25, 2010
Not Rated)
TLishus
Rank: Apprentice
Rating: 0%, 0 votes
I was having the same problem. Vista could not find the drivers to install for the Dell DJ. I seem to have found an easy solution. All you have to do is install the real player, then connect your DJ once the install is complete and search for the drivers again. It should show up after that. I tried it on both my computers with Vista and it worked. You can then uninstall the real player if you don't want it. Hope this works for you all also.
Was this helpful?
Yes
No
Solution #11
posted on Jul 06, 2009
Not Rated)
Elijah129
Rank: Apprentice
Rating: 0%, 0 votes
Download the MediaMonkey software, then run the driver for portable USB drives. Your dell DJ will work as such next time you boot.
Was this helpful?
Yes
No
Solution #12
posted on Dec 08, 2008
Not Rated)
justinkh25
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #13
posted on Oct 31, 2008
Not Rated)
GreyBike
Rank: Apprentice
Rating: 0%, 0 votes
One work-around if you still have your install cd's for XP would be to install the free download for Microsoft Virtual PC and use the XP drivers to sync your Dell DJ to your new computer. Here is the link for the Virtual PC home page:
http://www.microsoft.com/windows/products/winfamily/virtualpc/default.mspx
Watch the demo, it explains the features of VPC. MS is touting it as a solution to software compatability issues with Vista.
Hope this helps.
GreyBike
Was this helpful?
Yes
No
Popular Solutions for Dell DJ MP3 Player
Questions and Unsolved Problems for Dell DJ MP3 Player
Do you recommend Dell DJ MP3 Player?
Answer
Answer
my product serial no. for my dell digital jukebox was lost, i download the software but the product... (More)
Answer
who changes battery in dell dj
Answer
LOST the disc how can i put music in the dell mp3
Answer
how can i transfer the media (songs) from my dell DJ to my hard drive in my lop top????
Answer
I would like to transfer the music off of my DJ and onto my new Ipod.How can I do that?
14 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Oct 30, 2008
My Dell DJ 20MG MP3 player won't work with new dell computer vista operating sys..
Comment by taofeng_69, posted on Oct 26, 2008
Like everyone else ican't use my dell dj 20 with vista because i need new drivers which there seems to be none please let me now if any solution comes out
Comment by Guest, posted on Aug 21, 2008
same problem-- dell dj 20g won't work with vista
Comment by dpeoples, posted on Aug 04, 2008
I have a Dell DJ MP3 player. My computer crashed, so I purchased a new one. Now my Dell DJ will not work with the Vista
Comment by Guest, posted on Apr 20, 2008
I have 20GB Jukebox with vista and I have the same problem
Comment by Guest, posted on Apr 15, 2008
same problem with vista and dell digital jukebox mp3 player.  help
Comment by nash111007, posted on Jan 31, 2008
I have a Dell DJ Jukebox 30g and I have a problem with installing the drivers. It will download to 94% and stop. When I try to sync it it says that it isn't synced but yet me dj says "Docked" on the screen. I think my problem is I am running Vista. Can anyone please help?
Comment by Vista Hater, posted on Jan 03, 2008
I cannot get my Dell 20 GB Jukebox to work on my Vista system. The windows media players says my driver is outdated. I called Dell and they were no help at all. They said there was no driver for the jukebox for Vista. So basically it's out of date so too bad. Not very happy as I paid $400 and change the the player. I hope someone has a solution out there.
Comment by Guest, posted on Nov 21, 2007
I also can not use my Dell DJ with Vista. Tech support directed me to Dell2you for a solution. The Dell technician found a solution for a Dell DJ Pocket player. I gave him my service tag number so he could search for a solution. The only problem is I do not have a pocket player. Dell is no help at all. I now have two Dell PC's one with XP and one with Vista and the still can not help me.
Describe your MP3 and Digital Media... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
VIDEOGAME REPAIR SERVICE
(845) 592-2026
At Elite Audio Repair & Restoration it is our...
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
