I need to change the channels programmed into my tv
I got an old tv from a friend without the remote. It is a GE 8-2060. I got a universal remote, but I cannot get any channels on the tv other than what has been original programmed and my kids want to hook it up to their PS3. They have itr hooked up to AV variable thing on the back of the tv, but we cannot get the tv on the right line or channel to work the PS3. Can you help this electronically challenged single mom of 4 impaient kids?
  • gailee345 Mar 10, 2009
    My new remotes play only the channels that were programmed in from the original remote. How can I add the new channels?
    Using new remotes, I cannot get any channels other than the ones originally programmed on the old remotes. How do I add channels?
    Sergeant:
    Champion:
  • 373 Answers
Did you try the av button on remote
Posted on Jan 31, 2009
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
Mar 10, 2016 | Sanyo Televison & Video
How do you program a universal remote without having the codes for it
universal remotes usually come with a code list for different brands of tv or component, turn on tv or component, point remote at unit entering the code provided that coincides with name brand of unit. After code is entered, press the off button if it turns off component it should work for volume and channel changing. Hope this helps
Jan 09, 2012 | GE Televison & Video
My Old 1997 GE 31GT660 was working just fine yesterday with a PS2. My girlfriend moved it today while cleaning and now I cannot get the PS2 to work. We have no remote but a friend used a universal to get...
Ur girl friend clean around did she unplug the tv.Replug it back later?Bet u she did,that why the tv universal codes is gone.Reprogram ur tv unverisal codes again should solved this problems.Tries push the manual control button channel up like one or two times tv will be in input video again like video 1 or 2.
Jan 13, 2011 | GE 31GT660 TV
I have lost the manuel and remote for my GE49GW948
Best thing to do is to buy a universal remote - preferably RCA/GE brand since it will work without programming.
You should also be able to get to the autoprogram function of the TV by using the front panel buttons.
Oct 19, 2009 | GE 46GW 948 46" Rear Projection Television
Can't change input to play Xbox without clicker. With tv clicker I could access channel 00, which allowed me to play xbox. now the clicker is broke and I can't access channel 00. can i do this through...
The only way is with the remote. Try to find a GE or RCA universal remote. These remotes are designed around GE and RCA tv's and generally don't have to be programmed. (GE and RCA are both THOMSON made sets). Thanks
Oct 13, 2009 | GE 31GT660 TV
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
HI MY FRIEND sreeki.
Try this site:
It's the manual for a Phillips remote control. The codes should be rather universal. Otherwise, there is a way to program it without using a code.
Hope this helps :)
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Code for Sony tv
Hope this helps :)
Jun 10, 2008 | Philips Universal PH301S Remote Control
Cannot get DVD to Play on TV
Try the old RCA/GE channels of 90/91 or 92 to get to the inputs. Or try entering channel 00. Let me know if that works.
Feb 21, 2007 | RCA F32649 32" TV
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
