Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Doesn work at all
Since i bougt my fan it didnt work my remote it doesnt seem to send a signal to the receiver fan goes on no light and my remote doesnt respond
  • Anonymous Feb 01, 2009
    I have a problem with my reciever (model:UC7067RC-L,fan speed control E161552 8F36) for Hampton Bay 54 In.5 Blade ceiling fan.
    Where I can get new reciever?
I've had the same problem. Get the technical assistance phone # out of the manual that came with the fan. They can give you the proper part # so that you can then call Home Depot and special order the receiver. However, I have done this and then installed the new receiver as advised by Hampton Bay and I still am unable to get the remote to operate the fan or the lights. I know the fan works becaue I bypassed the receiver and wired directly to house power. I don't know if perhaps I have a bad transmitter (remote). I'll try that next. The fan worked for about a year, now its just a headache.
Posted on Feb 06, 2009
Hunter Ceiling Fan Remote Works Sporadically
The part that receives the signal from the remote control is the receiver which is located in the motor housing.
Apr 29, 2017 | Hunter 27148 Remote Control
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
The remote to my aircon doesn't seem to be sending a signal
If you get a mobile phone and select its camera, then look at the LED at the front of the remote thru the camera, press some keys on the remote unit and you should see the LED light up on the remote on the mobile phone camera screen (it picks up Infra Red which we can't see). this will let you know if the remote control is working. if it is, the receiver at the indoor unit is either covered with something, check thoroughly, or the receiver is faulted, replace via technician. Have fun Tim B TB Electrical
Nov 29, 2012 | Carrier Heating & Cooling
Romote control is not working.there is a battery in it ,red light comes up but fan is not there any way i can manually control the fan ,any button hided some where? or i can make sure remote...
normally in Hunter fans its not the controller but the receiver goes out, if your controller has a new battery and the receiver doesn't get the signal,, the fan isn't going to work, I've never been able to Locate Hunter receivers, tons of the remotes, you can contact them on line at this link
Aug 26, 2011 | Hunter (25417) Ceiling Fan
My ceiling fan/light goes on when I am not in the room. The remote is on the bureau. I sometimes put the remote in another room but the fan/light still goes on. Model 327185-060
The simple solution is to turn the wall switch OFF when, the fan is not in use. I really don't think the remote alone is the culprit. Because, you say it happens even when it's in the bureau or in another room. Remote controls for ceiling fans have a very short range and are generally infrared remotes, rather than radio frequency remotes. So, if the infrared signal does not reach the receiver's sensor in the fan, it won't function. If it's a radio frequency remote control, do you have any other remote controlled fans in the house? If so, does the suspect fan seem to turn ON after you have activated the other fan? If that happens, it means both remote controls are on the same frequency. Changing the frequency of one, should solve the problem. See your Owner's Manual for directions on how to reprogram the frequency codes.
If none of the above solves the problem, maybe you should contact the "Ghost Hunters" TV show.
Hope this helped you troubleshoot and solve the problem. Thanks for choosing FixYa.
Jul 23, 2011 | Hunter Heating & Cooling
We just bought a house that has 3 of the same fans. THey are hunter with remote and no pull cords. The master bedroom fan doesnt work. We tried to rewire it and the only way we could get anything to...
Hi Leanne,
Most fans have green, white, black and blue wires. Green is earth or safety ground, white is neutral, black is for the fan and blue is for the light fixture. Some fans may deviate from these commonly used colors in which case you should consult the instructions. Below are links to instructions for different Hunter remote fans, additional instructions for Hunter remote fans or you can look up your fan by model number or use. It appears that the built-in remote Hunter fans have no provision for controlling a light when the fan is wired from a traditional switch instead of using the included remote, as they have only a green, white and a single black that remains powered constantly to supply the remote receiver. The hand held remote transmitter tells the receiver to switch power to the fan motor and light bulbs as needed.
It is possible that the transmitter or receiver you're using in this room is not working. Try using one of the other remotes with the non-working fan by matching the code of the remote to the fan. If it doesn't work, try selecting a different code on the fan and match it on the remote (in case there's a problem with that particular code in this location). Try all (or as many as you care) codes to see if any codes work with this remote.
By this time, you should have either found a working code with this remote and are all done, or still have a non-working fan. Since you have tried more than one remote - and know that one of them worked in the other room, suspicion falls on a faulty fan or integrated remote receiver. You can replace the fan if you like with a traditional fan and light and purchase an after market or third party RF remote control if you no longer wish to get an integrated remote receiver.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 19, 2011 | Dryers
I have a quoram 73000 remote that the previous owner of this home uses to control a ceiling fan as well as the canned dimmer lights above the fan.I hink I just need to reprogram the remote because it...
I will assume you checked the batteries? These units have sequence matched signals. The only way to confirm neither has changed is to check both. It works like a garage door opener. 4 pins must match each other. On the remote, this is usually found where the battery goes. You will see the 4 pins. Up or down is the only option for each pin. That was easy. The hard part is getting to the receiver in the fan. At the ceiling there is a cover for the wires. 2 to 4 screws hold it in place. Remove the cover and you will see the receiver unit...probably stuffed in there very tight. Carefully remove the receiver to expose the pins. Check that they match the remote sequence. If they do not match correct to match and all should be good. If they match and the battereis are fresh, the remote or the receiver went bad. In which case you can get a universal, even by Hunter Fans at Home Depot or Lowes will work. Color match the wires if you are a DIY'r. Feedback is appreciated if this helped or not.
Jun 30, 2010 | Quorum 73000 Remote Control
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Wireless remote control extender
Possibly your new equipment doesn't use IR (infared) as the media for the remote. I have used the pyramid and different versions of it for DirecTV/Dish and most everything else for years with no major problems. occasionally a unit will fail, but that happens. If the red light blinks on the "transmitter" (no antenna) it should indicate that it is receiving IR from the remote. The "receiver" (antenna) has to be oriented correctly in front of the unit to be controlled. I put the receiver no closer than 5' to the unit. The signal coming out is a cone shape and it's easier to aim the further away you are. As a test, you could try using the remote to control a stereo or something else, even a fan. If the remote has a led or a dark red plastic cap on the front end, it should be an IR unit.
May 07, 2008 | Radio Shack Wireless Remote Extender...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
514 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
