Question about Husqvarna Viking 1
Thread breaks I have a husquvarna MD# 300 Designer 1 . it keeps breaking the thread.
    Brigadier General:
  • 8,619 Answers
Hi!
Check to see if the lower thread be tangled. Also, the bobbin could be threaded improperly in the shuttle hook. Rethread the bobbin in the shuttle hook.
How to detangle a thread---
  • When a machine stops operation due to tangled thread, do not turn the pulley by force.
    If the pulley is turned by force then, lower thread might not be picked up correctly and stitches might not be formed correctly.
  • If threads get tangled, remove a needle plate and cut the tangled threads by scissors or cutter.
  • Do rate the solution if you find it helpful & useful.
    Thanks
    Rylee
    Posted on Jan 30, 2009
    I DO NOT HAVE A MANUAL FOR 8708. I ALSO AM HAVING TROUBLE WITH THE UPPER THREAD,( PROPER THREADING NEEDED,) IT KEEPS BREAKING, PLEASE HELP. VINCENT
    The manual may help (assuming this is your machine):
    Crofton MD 8708 Instruction Manual
    The thread will break if the machine is threaded incorrectly. Be sure to ALWAYS RAISE the presser foot when threading the upper thread. Also, set the upper tension to the midway point. This is the standard setting for machines although there may need to be some tweaking to get the tension where you want it.
    Oct 20, 2016 | Sewing Machines
    Designer 1 se needles keep breaking
    Needle breaks
    1.the needle is damaged
    2.the needle is not correctly inserted
    3.wrong size needle for the fabric
    4.the wrong foot is attached
    5.the needle clamp screw is loose
    Feb 09, 2012 | Husqvarna Designer I
    I am sewing a quilt and my needle is in the right place but it keeps breaking. Please help. Also, the thread break often.
    here are something you might check
    upper thread breaks
    1.top tension to tight
    2.thread to thick or to fine for needle
    3.needle not inserted correctly
    4.thread caught on something-spool pin, tension area
    5.needle damaged
    6.needle thread is not threaded properly
    Needle breaks
    wrong size needle for fabric
    also check for lint & pieces of broke needle under the needle plate
    also the bobbin case area -take the bobbin & case out & check for pieces of broke needle
    here is a tip about needle & thread
    Cut 6-8 inch piece of thread of the spool you are going to use for your project
    Take the needle you are going to use for the project
    & insert the thread thru the eye of the needle
    & lift one end of the thread to a 45 degree angle
    & if the needle is the right size for the thread it will slide down the thread
    But if the needle hangs on the thread you need one size larger needle for the thread
    Oct 21, 2010 | Husqvarna Designer I
    When I am trying to do an embroidery design, the top thread keeps breaking. What could be the cause of this?
    check your thread tension
    check needle could be bent-blunt or damaged
    thread could be caught on something
    on some sewing machines the thread comes off the thread take up lever
    Sep 23, 2010 | Husqvarna Designer I
    Two problems : 1. I have a Designer 1. When e
    Ok,...both problems are probably related to the same componet, your upper thread tension assembly. It has a sensor which sends the message when the thread is broken. It also would be the culprit for looping. There is not much you can do except look for lint or loose threads in the threading paths around the upper thread tension assembly and remove it if you see some. You could try setting the upper tension to larger number to see if it will help but sooner or later it will need to see a tech.
    May 05, 2010 | Husqvarna Viking 1
    Husqvarna Viking Designer I breaking needles
    Make sure that the metal plate is locked into position- Hope that helps!
    Jan 20, 2010 | Husqvarna Designer I
    Husqvarna Viking Designer 1 keeps breaking needles
    The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
    May 21, 2009 | Husqvarna Designer I
    Thread breaks when embroidering
    Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
    Jan 04, 2009 | Husqvarna Designer I
    Breaking thread
    Try adjusting the tension in the "Set" menu. "Tweaking" anything else may end up costing money.
    First, make sure the hook area under the bobbin case is free of debris. Try a new bobbin and a new spool of thread with a new needle, full inserted. If the needle threader isn't lining up, the needle may not be in right.
    Jul 12, 2008 | Husqvarna Designer I
    Sewing Machines Logo
    255 people viewed this question
    Top Husqvarna Sewing Machines Experts
    Douglas Plant
    Douglas Plant
    Tally Girl
    Tally Girl
    Wayne Fellows
    Wayne Fellows
    Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
