Question about Siemens A40 Cellular Phone
Battery is with power for only 3 hours problem?
Battery only keep power 3 hours why?
  • 50 Answers
The battery probably is old and used up. Replace it.
Posted on Jul 30, 2007
Kindle keeps turning itself off
This is usually a sign of either a failing charger or Kindle, let's try to hard reset the Kindle.
Step 1: Press and hold the power button for 60 seconds
Step 2: Plug the Kindle into the changer, press and hold the power for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Turn on and use the Kindle, if it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
Mar 26, 2013 | Amazon Kindle Fire HD
My battery on my iphone runs out in 2 to 3 hours. What to do?
I think you must check your charger and if ok replace your battery
Mar 31, 2008 | Cell Phones
My phone just out of the blue just frooze now it just powers up and wont turn on
keep the battery out for 30 minutes, keep the charger UNPLUGGED from the phone. Then put the battery into the phone and charge it, (with the phone off), for the determined time in your cell phone's user manual. (Recommended 3-5 hours)
Apr 04, 2012 | Samsung UpStage SPH-m620 Cellular Phone
No problem just bought a mpd-1760 from someone its brand new never even been used ,but no instructions/need to know how long to charge battery for first time or at all //charging time for battery to watch...
To charge the battery back you want to
  1. Turn the power off the DVD player first as the battery pack will not charge with the power on.
  2. Attach the battery pack to the player.
  3. Connect the AC power adapter and the power cord to the player.
  4. Charging will now start and the Power/Charge indicator should now be orange.
  5. Do not unhook either cord until the Power/Charge turns off.
  6. Time of charging is approximately 4 1/2 hours.
  7. The battery pack will more than likely get warm while charging. This is normal. Keep it as much in the open as you can for the best ventilation possible.
  8. You will get a low power indicator on the screen when the battery has a low charge.
As for playback time you will get about 2 1/3 hours of actual playback and about 4 hours of standby with the DVD player actually on.
Regards, Tony
Apr 12, 2011 | Mintek Televison & Video
I need to know how to use my new laptop battery correctly.
The first time you charge the battery allow 12 to 16 hours, after that 2 to 4 hours or when battery is charged. If you go on battery frequently drain it right down before charging it, this will give the maxi-um performance and longevity.
Mar 16, 2011 | Computers & Internet
My clock radio wont keep the time once I set it the clock advances 2 to 3 hours ahead
I took the back up battery out and unplugged the unit for about 20 minutes before powering the clock back up. Once I powered the clock up I re-inserted the backup battery.
Jan 17, 2010 | Emerson Smartset Clock Radio
LC 97 keeps losing power after about about 3 hour of
Drive over to Autozone or Oreillys and have them check the charging system while it is running. You also need to check for the "draw" of power used by the car. They may not have the gauges for that portion of the test.
One item that is silent and draws a lot of power is the rear window defroster. I don't know offhand if it is a dedicated fuse or if there are several items on the same fuse. You could try pulling the fuse for the rear window defroster.
Your air suspension can draw lots of power if the air compressor keeps running.
If you are running down a fully charged battery and all the power of an alternator, something is either glowing, or a fusible link is blown and the charge is not getting to the battery.
Sep 10, 2009 | Lincoln Continental Cars & Trucks
BATTERY LOW, POWERING DOWN! SANSA M240
Hey,
Try these steps, if they aren't of any help, you may have to have the vendor replace your mp3 player.
SOLUTION 1 - Reset the device.
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
SOLUTION 2 - Power cycle the device.
STEP 1 - Remove the battery
STEP 2 - Power cycle the player
1. Connect the device to the PC.
2. Leave the device connected for about 2 minutes.
STEP 3 - Turn on the device
1. Disconnect the player from the PC.
2. Insert a fresh AAA battery into the player.
3. Turn on the player.
Jan 16, 2009 | SanDisk Sansa m240 MP3 Player
T-Mobile sidekick 3 keeps shutting off
i have the same problem. what i did is i went to the tmobile store nd asked themm.. they told me the battery is loose.
soo wat could tell you is that put the battery still
Sep 20, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick 3 keep shutting off!
is it shutting off because the battery is dead or is it just random?
Siemens A40 Cellular Phone Logo
286 people viewed this question
Top Siemens Cell Phones Experts
Stormi  Paulk
Stormi Paulk
Colin Stickland
Colin Stickland
Are you a Siemens Cell Phone Expert? Answer questions, earn points and help others
