Question about Video Game Consoles & Games
My xbox 360 power supply/brick goes from orange to red as soon as I plug it in the back of the console.
  • 68 Answers
When the power box says RED, that means that the problem is your power supply, try another power box if you have a friend or relative nearby, and if it works on another brick that means you have to contact xbox support and check the warranty of your brick, but if its already out of warranty. You need to purchase a new power supply that costs $79.99 ( Only available through Xbox customer support ) - Shipping and Delivery will be covered by microsoft
Posted on Mar 26, 2009
My xbox 360 had gotten the red ring, so I heated the mother board with a heat gun and then replace the thermal paste, now the power brick is orange/yellow when plugged in, turn on the box it goes green for...
We STRONGLY recommend you not to use heat gun as it can heat other components, when your system have 3 red light and no fan are spinning it means that one of your fuses has gotten damaged and no power can go through your GPU chip.
Thanks
www.1RepairStop.com
We Fix Everything
Aug 31, 2011 | Microsoft Xbox 360 Console
Orange light on brick plug it into my xbox and light goes red and it wont switch on
the 360 has a power fault usually it is drwaing toomuch power for the relay in the brick to switch over, try removing the hdd and any wired controllers you may have in it and see if it will turn on
Jul 01, 2011 | Microsoft Xbox 360 Console
The power brick on my xbox 360 is red and is not overheating yet i smaell burning plastic from my xbox 360 console anyone have any tips?
A red light on the xbox 360 power brick usually indicates the Xbox 360 console has a short circuit. Here is how to be sure:
1. Try unplugging the power brick from the wall and from the xbox 360.
2. Wait about 30 seconds and plug the power brick into the wall power outlet.
3. Make sure the indicator light on the power brick is orange. ( If it's not orange then get yourself a new power brick and try again ).
4. Plug the power brick into the Xbox 360 console and try to power it on.
If your power brick turns red or you get an immediate three red ring error than you will need to have the console professionally repaired.
If your warranty with Microsoft has expired; the company I work for GATpro Repairs offers this service at a low flat rate and we pay for the return shipping.
Good Luck and I hope this has helped!
Michael GATpro Repair Technician
Jun 14, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
Red light on power box for 360
i have to personally dissagree with 'wildbear' :-)
well not actually dissagree but i think the problem will be at lot less technical than all the writing he has done.
a simpler check.......does the 360 'switch on' ??
i assume with a red light on the power brick it dosnt ??
the problem is more likely a faulty pin (terminal) inside one of the USB slots you have been using for either a controller charger or wired controller (or a usb memory stick to play music thru ur xbox??)......plugging chargers/wired controllers in & out of either the 2 front slots (behind the flap) or the 1 at the back can sumtimes bend one of the terminals causing it to touch the outer casing of the usb slot ?? if it does this it shorts the board of the 360 which in turn stops u powering up the 360 all together :-(
one of the signs of this is a 'RED' light on the power brick & the 360 not powering up at all !! but sumtimes the power brick light will stay orange or even green.....even with this fault ! it dosnt always turn red !
One way to rectify it is (un-plug the powere brick from the mains first) & unplug ALL USB CONNECTIONS TO THE 360 !! (controller chargers ect) & try powering up the 360 !! (after plugging it back in)
if this fails ur gonna need a torch & a little screw driver (or tweezers) un-plug everything from the 360 & look inside ALL usb slots you have used ! check to see if any of the prongs have bent accidently whilst plugging in & out chargers ect ..... if they have straighten them so they are not touching any of the sides of the usb slot....
after doing this ...plug back in and 'hopefully' Whoooop Whooooop :-)
hope this helps ??
failing this it maybe as wildbear suggests & its a problem with the power brick altho i very much doubt it ?? they normally way out live an xbox !
remember thumbs up if this helps :-)
Jan 01, 2010 | Microsoft Xbox 360 Console
My Xbox 360 won't turn on. When I plug the power cable into the wall, the orange light on the power brick lights up as normal, but if you plug the other end into the Xbox, the orange light starts blinking....
Sounds like a bad power supply, or on two occasions I have found that one of the USB ports had a bent pin which was shorted to the metal housing, which wouldn't let the unit power on. So check all of the USB ports
Dec 03, 2009 | Microsoft Xbox 360 Console
Xbox 360 has orange light on the power brick,no power to console?
Mine has an orange light and works fine. i think that's standby mode. it turns green as soon as the 360 powers up. try replacing the power cord that goes from the 360 back to the power block. It may be faulty.
Nov 21, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
78 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
