Question about Labtec 961307-0914 Webcam
Labtec Camera HELP!!!!!
Got cam for xmas installed it and it worked fine. then i had to uninstall it for some reason (cant remember) reinstalled it and it says make sure video cam is working so i do then i click in the icon and it says it is in use by another application. Troubleshooting involves unplugging all usb's and then reinstalling the camera and excatly the same happens. I have uninstalled, re installed, unplugged all usb's plugged in all usb's and its still the same. When it syas test to see of working i wave my hand infront of cam and i can see it on screen then it says your camera has been installed then i click the icon and am back to the beginning and it wont bloody work!!!!!!!!! Please help!!!!
First, have you tried restarting the computer? If that doesn't fix it check the task bar in the bottom right to see if the webcam software is running down there, then use ctrl-alt-delete to check the task manager to see if any webcam software is running there. Only one program is able to use the webcam at a time so you just have to find what other program is using it.
Posted on Jul 30, 2007
6ya staff
SOURCE:
Labtec webcam not working why i did every thing my computer not detecting this ****** i install all the posible drivers already i used window xp. I hate this man.
ok, uninstall all related drivers to this camera,
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
Regards
gewiz.
Dec 05, 2009 | Labtec 961307-0914 Webcam
The camera is not working
hi you probably need to uninstall it disconnect it. reboot. and reinstall the driver that came with it. or if you dont have from here.
http://www.labtec.com/index.cfm/service/listing/AMR/EN,crid=68,crid2=1764
Then when installed reconnect cam and enjoy.
If this helped you, please vote for me
AndystUK
Aug 31, 2009 | Labtec Logitech 1200 Webcam
Labtec webcam 6.0.1.
Try to install ManyCam software from Internet. It supports a zillions of webcams
Mar 26, 2017 | Labtec Webcam Pro
Cyberlink YouCam Avatars Problem
my cyberlink youcam just stopped recording with sound or playing out sound even on videos that were already on there any played fine before...I checked the settings and it said there was no sound devises but media player runs fine. help please :)
Dec 30, 2008 | Computers & Internet
Uninstall using revou ninstaler and remove all registry. restat computer. then try to install it again. but remember before doing this create a system restore point.
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Nov 30, 2008 | Labtec 961307-0914 Webcam
Labtec webcam
LAURA,HELPS.RICHARDM69UNPLUG THE CAM AND LOOK IN DEVICE MANAGER.FIND YOUR CAM AND UNINSTALL THE DRIVERS.REBOOT.DOWNLOAD NEW DRIVERS FROM WEBSITE FOR CAM.MAKING SURE ITS THE RIGHT MAKE AND MODEL AND ITS THE DRIVERS FOR YOUR OS.THEN REBOOT.PLUG CAMERA BACK IN.SYSTEM WILL DETECT IT AND LOAD THE DRIVERS.HOPE THIS
Nov 29, 2008 | Logitech Webcam
Cams not installing
Normal 0 Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Oct 27, 2008 | Labtec Logitech 1200 Webcam
Usb wont fit
my computer is an HP Pavilion slimline s33001 The cam is Labtec i cant remember the # but of the four its the smallest slimmest dark one.It wont fit in either computer we own.the usb
is so odd yet our older Labtec cam is fine on both pcs.
Jun 20, 2008 | Labtec Webcam Plus 0403
Logitech quick cam communication deluxe will not install
Ok, take a breath... What has happened, is although you uninstalled the Logitech software, the folders still exist (as with any program uninstallation).
Unless you're comfortable with poking around your C drive, then download and run a program called "ccleaner" at www.ccleaner.com, which in a normal scenerio will remove redidual files left behind by an uninstall.
Once you have installed ccleaner, choose "tools" and use their uninstaller to remove the logitech software (if it shows on the program list).Even if it doesnt show, still run the "cleaner" function", as there will always be temp files lurking around that could mess up an installation.
Then, go to Logitech's site and get the latest software for your camera model.
Be sure to NOT plug the camera in until it tells you to do so!! THIS IS VERY IMPORTANT!!!
You may have to go into Skype's video configuration utility to setup the cam, but I think you can take it from there. Good luck!
Jan 05, 2008 | Logitech QuickCam Pro 4000 Webcam
Labtec Problema
Why I cant use my cam?
Aug 30, 2007 | Labtec 961307-0914 Webcam
Labtec 961307-0914 Webcam Logo
80 people viewed this question
Top Labtec Computers & Internet Experts
Ekse
Rob Hill
Rob Hill
Are you a Labtec Computer and Internet Expert? Answer questions, earn points and help others
