We have a dynaGlo propane heater purchased from Home Depot that fits onto a small cylinder (grill) type tank and the part that adjusts the propane output has broken. How can we get this replaced?
I have this problem. Home Depost carrys no replacement nor does the local propane supply
Posted on Mar 09, 2009
Ace lp troubleshooting
They have adapters for this. Try Home depot
Sep 02, 2017 | Weber Grilling
I purchased a used Masterbuilt veranda gas grill. The gas regulator fits a small propane tank. Is it possible to replace the regulator so it will fit a large sized propane tank?
Yes, it can be converted to accept a 20 Lb LP grill tan. Contact Masterbuilt Customer Service
1.800.489.1581 to obtain the new hose/regulator assembly.
Hope this helped you and Happy Grilling!
Jul 22, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
Weber grill three burner. New tank of propane but
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 29, 2010 | Weber Genesis Silver B Grill
I have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Oct 07, 2009 | Thermos Stainless Steel Gas Grill
Where can I find a (1lb) proprane tank for portable
That should be a screw on type of propane cylinder, which should be readily available at stores like Wal-mart, Sears, Menards, Lowes, Home Depot, Etc.
Apr 19, 2009 | George Foreman GGR62 Grill
Broken adjuster for propane heater
Broken adjuster for two burner attachment. Cant find a
Jan 30, 2009 | Dyna-Glo Double Tag-a-long Heater
Gas Flow Problem
Replace the regulator and hose assembly that screws onto the propane bottle. I had the same problem on two patio heaters and my 4 burner grill. You can get regulators and hose at Home Depot, Lowes, Northern, probably Meijers, etc. Check the fitting on the end of the hose for the correct gender, male or female, size, and hose length. You can get a fitting in the plumbing department to change the gender.
I can all but give you money that this will fix it.
Jan 15, 2009 | Char-Broil Performance 463463006
When I go to start the barbeque I have to unhook the tank everytime to get the gas to flow from the tank to the grill.
You need a new regulator. These can be purchased and Lowe's, Home Depot, or your local propane supplier. (the ones at your local propane supplier will be of better quality and adjustable.)
Dec 06, 2008 | Kitchen Ranges
Regulator freezing up
1. Are you using a portable LP cylinder? LP Regulators freeze up when the liquid part is the propane is flowing through the regulator this is caused by an overfilling of the propane tank.
2. If the BTU capacity of the regulator is not high enough to cover the BTUs of your grill, the regulator is working too hard and potentially pulling liquid (not vapor as it should)
I would suggest calculating the BTUs of your grill and looking to see what the capacity of the regulator you are using.
You can also read this about regulators LP Gas Regulators 101
Nov 13, 2017 | Brinkmann Charmglow 810-7400-S Propane...
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
