Question about Kenmore Dishwashers
Dishwasher not lighting up, burning smell
If my electronic panel doesn't light up, it smells like burnt rubber and water is collected in the pan, I presume it is dead and I should get a new one. Is that correct?
  • 750 Answers
Hello stevelana
Here is an interesting report I wrote!!!!!!!!!!
Repair or replace?
When to pull the plug on your old dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your dishwasher,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your dishwasher is under warranty or less than four years old ,
paying for a repair makes sense.
Note that dishwashers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your dishwasher is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new dishwasher.
Data also shows that it doesn't pay to fix a less-expensive dishwasher
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of dishwashers you replace are likely to end up in a landfill.
My name is Huuum
Please leave a solved rating before you sign off!
Posted on Jan 31, 2009
Hotpoint DWF31 dishwasher went bang mid cycle and mild smell of burning plastic. Still powers on, lights on correct setting but stuck at 77 mins with nothing happening. Water still inside. Any ideas
Sounds like you have burnt something. May have shorted out. Shut it down and pull the plug or could maybe cause a fire. Get a professional to look at it.
Dec 19, 2016 | Hotpoint Dishwashers
My LG washer stopped mid-load at spin cycle, how can I fix this?
It sounds like a serious fault if there is no power the fuse has gone or some item has burnt out . You will have to arrange for a service engineer to look at it more closely.
Apr 28, 2015 | LG WM-2277HW Front Load Washer
Burning Smell inside siemens dishwasher
Most likely the smell is coming from a motor that is having a hard time turning, so it's overheating. Don't run it or it might catch fire!
Apr 22, 2017 | Siemens 24 in. SE64A630GB Built-In...
My dryer has burnt smell just buzzes but doesn't
Check the motor, it's sticking or already burned out
Mar 26, 2013 | Dryers
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
What is causing the bad electric smell from my dishwasher?
one or more components is burnt on the board of the unit. Or there might be a bridge of wire which is causing the smell....
Jan 05, 2012 | GE Dishwashers
Battery light on and a strong burnin rubber smell
SOUND LIKE ALTERNATOR SHAFT BEARING FAILING CAUSING ALTERNATOR PULLEY LOCK OR PUT DRAG ON DRIVE BELT CAUSING BURN RUBBER SMELL OR DRIVE BELT LOOSE CAUSES BELT SLIPPAGE MAKE BELT RUB AND BURN.WHEN YOU SMELL RUBBER BELT BURN SMELL WATCH OUT DRIVE IS GOING TO BREAK.
Aug 04, 2011 | 1983 Ford Fairmont
My dishwasher won't drain. Repair man is telling me the motor's burned out. Does this sound right?
Chance are there. If repair man says motor is burnt, he can always show you the motor. You can easily smell the burnt smell.
Let him replace the motor and collect the old motor. that is the only way you can make sure. Hope the repairman has checked all the the other points. Before replacing the motor, find out the reasons for motor getting burnt! No water seepage into the coil, no high voltage in your area etc.
Sep 17, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Dishwasher not working
The motor may be burned out or there may be another electrical issue which would also cause the symptoms you describe. Call around and try to get an estimate, and at the same time look at new ones on sale.............one question is how secure will u feel with that maching......now that it has acted up like this.
Sep 07, 2009 | Dishwashers
Dishwashers Logo
160 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
