Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
Need a higher bulb than 100w, Do they make them for this tv set?
I have a Zenith E44w46lcd. It got very dark so I changed the lamp bulb # ze6912voooo6c. It is still dark and I was wondering if they made a bulb that has a higher than 100w that I can put into the tv set? Patsy Tyre fivetyres@aol.com
  • fivetyres22 May 11, 2010
    How can I clean the colorwheel myself?
    Scholar:
  • 87 Answers
You will burn up the plastic components in your television if you go with a higher wattage.The cooling system is designed only to handel the specified wattage.Also your set will shut down doe to increased internal temp.I do not reccomend using a higher wattage.You may have dust build up the optics of the light engine or a dirty colorwheel.LG made optics are notorius for getting dirty.Time for a professional cleaning.
Posted on Jan 30, 2009
Should I replace the bare lamp or the complete housing for the bulb in my Zenith E44W46LCD TV?
Replace it with the complete housing with a bulb inside.The easiest and the safest way to do a replacement of a tv projection lamp.
Sep 04, 2011 | Zenith E44W46LCD 44" Rear Projection...
I replaced my bulb 6912V00006C on my Zenith E44W46LCD and when i plug the TV back in a red light comes on. when i press power a green light blinks for 5 seconds and then goes back to the red light. I don't...
YES, this set is difficult to replace the lamp correctly---it is very likely when you put the cartridge back into the set the two pins on the back did not properly engage inside the set.
Remove lamp and try again, if set was working before and now different problem, the lamp is not properly seated.
If I remember this model, just the bulb is available, you have to take the housing apart and replace bulb--if not perfectly done plug on back with two pins will not engage.
SD TECH
Sep 10, 2010 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD SCREEN GOING DARK
The lamp will dim as it ages and will do so quicker as it approaches end of life.  Do you know how many hours the lamp has been used.  How old is the TV?
May 27, 2009 | Zenith E44W46LCD 44" Rear Projection...
Lamp reset.
there are 2 clocks 1 for lamp and 1 for total, the total you cant change. dark picture, make sure your got same wattage lamp for replacement, I find original Philips lamps the best. if it continues follow manufacture instructions on cleaning mirror and lens.
Apr 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith replacement bulb
I would suggest to remove the lamp from your TV and check it. You can also just buy the lamp without the other hardware.
This site seems to have good prices.
Let me know if you need any more assistance.
Mar 26, 2008 | Zenith E44W46LCD 44" Rear Projection...
Color Fading on Zenith E44W46LCD
you neeed to change the lamp. the access is located on the right side of the television. you can buy the lamp for about $125 from discount-merchant.com
Mar 10, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD tv
TAKE THE FRONT COVER OFF THE PANEL AND REMOVE THE BULB USEING A PHILLIP SCREW DRIVER AND JUST PULL USING THE HANDLE ON THE OUTER COVER OF THE BULB.
Feb 24, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD Lamp Access Door Location
I found the location to get at the lamp. If you are loking at the front of the TV there is a small panel at the bottom of the right end. Two screws, remove panel, two screws inside and a small handle that lifts so you can slide the unit out. 4 screws on top of the cage that the lamp sits in, carefully slide up the silver bracket holding the bulb, be careful the edges are sharp. Remove the bulb from bracket and remove the 2 cables attached to the bulb. Now just do the same but in reverse. Make sure you wear plastic gloves that should be provided because if your fingers touch the lense you could be out the price of the lamp.
Aug 31, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
