Question about Apple iPhone Smartphone
My iphone blanked out. all it does is show the apple icon and it keeps restarting. itunes does not recognize it when it connected to the pc
Turn off iphone, press and hold home button, plug your cable to computer (make sure you already open itunes on your computer before you plug it) still press home button until you see on your itunes said "your iphone on safe mode" realese home button and click restore.
Posted on Jan 31, 2009
My apple ihone is disabled connectto itunes
There are many reasons why iTunes will not recognize your iPhone, whether it's dust or dirt blocking your dock connector or a system setting gone wrong. No matter what model iPhone you have, here are a few suggestions for helping the problem of iTunes not recognizing iPhone:
1. Generally speaking, when iTunes does not recognize iPhone, it may have something to do with the version of iTunes. If you are using an old version of iTunes on your computer, it may not be capable of recognizing your iOS devices. So updating iTunes to the latest version is a fastest way to get the problem solved.
2. If you are running iTunes in the latest version, but still can't get your iPhone recognized, you may want to take a look at your computer, sometimes if your computer lacks necessary software, it might lead to the malfunction of iTunes.
3. USB port on your computer can be another reason why iPhone not recognized by iTunes. So you can try more than one USB port to see whether the USB port works well.
4. Of course, your iPhone may also be the cause of iTunes not recognizing iPhone. At this moment, you can restart your iPhone by holding the Sleep/Wake button and Home button at the same time until you see the Apple logo, then connect iPhone to computer with USB cable again.
5. You should also make sure your iPhone trusts your computer, because after changing a new system on computer, your iPhone will regard it as a new computer. What's more, you should check out whether Apple Mobile Device Support is installed on computer.
6. After checking out all the aspects mentioned above, you can try to connect iPhone to computer with the USB cable again.
If none of these methods work out, you may want to try set your iPhone up as new after iTunes not recognizing iPhone. You only need to tap General > Settings > Reset > Erase All Content and Settings, and then choose Set Up as New. When you have set iPhone up as a new device, you are able to connect iPhone to computer with USB cable. But before erasing all contents on your iPhone, you may want to back up iPhone files to computer to keep them safe.
http://www.leawo.org/tutorial/what-to-do-when-itunes-not-recognizing-iphone.html
Feb 07, 2017 | Apple iPhone Cell Phones
How do i download songs from my pc itunes to my iphone 4
There are 2 ways,
1) sync music to your iphone through itunes by selecting the music tab on itunes and select the song you want to sync
2) sync by manually dragging your music to the iphone icon in itunes. you will need to click off the box "manually sync files to iphone" at the bottom of itunes
Nov 21, 2010 | Apple iPhone 3G
Well my iphone keeps blinking i tried connecting it to itunes but it wont reconize my iphone niether will the iphone show any cable on the screen it just keeps blinking
To do an emergency restart of the iphone, press and hold down both the home button and the sleep/wake button at the same time.
If your iphone still hangs when starting and will not be recognized in iTunes then follow these steps:
Make sure the device is off before attempting this!
  1. Press and hold down the Home button for about 10 seconds until a yellow triangle with a text which says Please Connect to iTunes appears.
  2. Plug the iPhone into Mac or Windows PC. Release the button if you haven’t.
  3. Run and open iTunes if it’s not already opened yet.
  4. iTunes will prompt a message that says iTunes has detected an iPhone in recovery mode. Click OK.
  5. You will be taken to the iPhone pane. Then, click on Restore.
  6. Wait for the full restoration process to complete, and the iPhone will be back to the original settings state as when it left the manufacturing factory, typically a working phone again if you face any problem, unless it’s hardware related.
Jun 29, 2010 | Apple iPhone Smartphone
I was running updates with my phone connected to itunes on my computer, power went out during the middle of syncing. now it wont turn on. i hold both buttons and the apple icon appears for about 5 seconds...
Open up itunes first.
You need to restore iphone in DFU mode.
Restart computer and use a different USB cable if possible.
Hold power button 10 seconds, don't let go, now push in home button 6 seconds.
Now release only the power button.
Keep holding 'home' button until itunes sees it and allows you to restore.
click restore.
If this still does not work then do all of this on a different computer.
Dec 21, 2009 | Apple iPhone Smartphone
I power on my iPhone and I get the black background with the apple icon in the middle, after a couple of minutes I see the spiral loading beneath it for a few minutes and then the iPhone restarts again,...
first if itunes recognizes the phone just push the option for restore. If not then you should try a force reset. That is accomplished by holding the home screen button and power button down together at the same time. when the screen resets and shows the apple symbol keep holding the home screen button and plug the phone with cable already connected to the computer. after a few seconds itunes should recognize the phone is in recovery mode and make you do a restore. if that does not work you have a hard ware problem and you need to get your phone replaced as long as it is in warranty at a store.
Jan 25, 2009 | Apple iPhone Smartphone
How do I add itunes music to iphone from computer itunes library? Is this possible or do I have to buy all new songs from the iphone Apple Store?
Yes it can, connect your iphone to your computer, at this point as soon as your computer recognizes the iphone itunes should open up.. if it doesn't just open it up yourself. Now on he left where all the playlists are there should be an icon with you iphone there, click on it. Now to the right there should be a tab labeled "music", click on it now you can select wether all your music will transfer over or just certain playlist. There you go.
Ciza
Oct 30, 2008 | Apple iPhone 3G
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Apple iPhone Smartphone Logo
76 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
