Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Hi, I can't find my booklet but my elements powered by WD harddrive is now full. Do I delete everything on it and will it start to backup again. Because I keep getting something up on my computer telling me I can't backup as it is full.
  • 80 Answers
If you clear/format the external and you have whatever program you are using to backup, it will start backing up again. Make sure you do not delete any critical files you have backed up before wiping it.
Posted on Jan 30, 2009
Hi My Seagate drive states it is full and backups have stopped. Why is this happening and how do i fix it so it starts backing up again. Thanks
If your seagate drive is full then it wont let you back it up you will need a bigger storage space or by cleaning out your computer you can remove the backup by going into backup options locate by double clicking the flag in the bottom right hand side of your monitor and delete it or by going into your seagate and deleting the backup folder forcing it to back it all up again
Jun 29, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
I want to back up my hard drive onto my Elements external drive. The computer says that the Elements 3607 does not have enough space. What do I do?
Well first of all check how many free space you have on your ext. drive. If you DO have enough to back-up your files,then i would suggest you right clicking on your ext. drive,choose properties and format it,but beware,formating will delete ALL your data on external drive.
If you think i was usefull,click on Thumbs up button,cheers!
Mar 07, 2011 | Western Digital Elements powered by WD 320...
Power loss in external harddrive
Hi mjcole,
Couple things. What model WD drive do you have? Plugging the laptop adapter into the drive chassis may have fried the chassis. You can buy a new chassis and put your drive into it, or you can buy a new power supply in case the one you have has gone bad and you did not realize it. Not likely though.
The power requirements are very specific and the laptop power supply may have been to much for the WD drive.
Feb 12, 2010 | Western Digital Elements powered by WD 320...
I bought a new WD Elements 350gb external hard drive and it came with a Memeo software CD. It says to insert CD before starting backup. I do not appear to be able to use this external hard drive as a plug...
This software is not linked with the drive (with this particular drive you only get a trial version anyway). Just remove the software from your PC.
Start > Control Panel > Add or Remove Programs > Remove Memeo/ WD Anywhere Backup.
Once you have done that, you can delete everything on it (assuming you never manually put something on it apart from the backup). If so, back it up onto your PC, another drive or CD.
Jan 25, 2010 | Western Digital Elements powered by WD 320...
I clean my drive every monday... but if i look in backup exec it says it has not been cleaned since 2006... and now my backups are failing and i cannot figure out why!
Please do a defrag on the harddrive. Also delete temp file and prefetch. command is
Click start-run -type %temp% hit enter it will open in folder showing all files select all and delete all.
then Click start -run type prefetch hit enter
Empty the recycle bin .Then check good luck.
Aug 24, 2009 | Symantec Backup Exec 10d for Windows...
I can't backup files, because it says I have no more room. How can I fix this?
Delete some files or backups. If your backups are appending or creating a new file every time without replacing the old ones, it will eventually fill up.
If the drive is not full, it may be your file system. If the partition is formatted FAT32, you have a maximum file size of 4 GB. The backup will proceed until the file size reaches 4 GB, then it will close out and the rest of the files will not be backed up.
Using Disk Management, you can create a new partition, this tiime NTFS. Unfortunately, you'll lose all files on the drive when you partition so you'll need a place to move the files to temporarily.
Aug 08, 2009 | Seagate Maxtor OneTouch 4 500 GB USB Hard...
No power to external harddrive
Yes, without a doubt!
I highly recommend sending it back for repairs or replacement. Most are covered under a 6 month warranty depending on the deal, and the country you are in as well. And computer shops don't generally fix things like External Drives, since they are not as a important part of a PC, but as a backup or storage device.
Good luck mate.
Jun 30, 2009 | Western Digital Elements powered by WD 320...
My D: drive is 99% full how do I free up disk space ?
Music, video and pictures use the most hard drive space. Store them on a disc or on line storage site. After the delete or removing as advised, defrag you hard drive. This should free up space. Get rid of any programs you don't use. As long as you don't delete hidden files you should be fine. Hope this helps. If you are using windows XP go to start, control panel add and remove programs and delete only the programs that you installed and remove only them.
Jun 21, 2009 | Compaq Presario Notebook
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
117 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
