Question about Dell Dimension™ 4600C PC Desktop
How to open case for a dell dimension 4600c computer.step -by step
    Scholar:
  • 51 Answers
Here's a Diagram Snap-Shot of the first step. (just enter the verification code and view.)
That's it for opening the case!
More information (General Everything about and how-to Guide) on your Dell can be found HERE.
The Dell Guide Link is a .pdf file from Dell's Support Section.
I Hope This Helps.
Posted on Jan 31, 2009
Cr2032 coin cell
It has A small Nickle shaped Battery on the Motherboard to keep time
Oct 10, 2013 | Dell Dimension 4600C PC Desktop
I need to replace the motherboard battery on this Dell Dimension 4600 tower. How do I open the casing ?
All the PC are more or less the same thing...
Here's a video tutorial of how to open it.
Aug 24, 2011 | Dell Dimension™ 4600C PC Desktop
Dell Dimension 4600C Compurter running fast and
Try to check the fan and the inside of the desktop for any dirty things in there. Especially check the fan to see if something is stuck!
Mar 04, 2011 | Dell Dimension 4600 PC Desktop
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
No output to video monitor
I would suggest that you can use PowerColor ATi Radeon 9550 SE 128MB 64bit DDR AGP 8X Low Profile Video Card which works fine with Dell Dimension 4600c. Please write back to me or place a comment if it works for you or if you need any further assistance.
Good Luck.
Mar 31, 2010 | Dell Dimension 4600 PC Desktop
I have a dell 4600c When i turn it on it powersup but no video
unplug your computer
Open the computer case up, reseat the memory by removing it and putting in one ,and starting the system,and check all power cables are connected. Do this to each memeory module that you have to test your memory.
IF that doesn't work remove , memory,hard drive cd/dvd drive,and printer etc.turn system on and if it does not beep then the motherboard is bad. The motherboad should beep to indicate that their is no memory.No beep equal no response from the motherboard. hope that helps.
Jan 10, 2010 | Dell Dimension™ 4600C PC Desktop
I have a dimension 4600c. installed a new power
The power supplies have extra connectors which are not used.
Try doing a system restore to an earlier date when your computer was working ok.
Restart your computer and hit F8 while it is booting. When the menu comes up, select "Last Known Configuration"
This will bring it back to a time when it was working.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 11, 2009 | Dell Dimension 4600C PC Desktop
Problem with Dell 4600C
Dimension 4600C driver
Developer: Dell
Version: 1.16.0
System: Windows XP,Windows 98,Windows ME,Windows 98 SE,Windows NT SP4,Windows Vista,Windows 2000 SP4,Windows 3.11,Windows NT SP3,Windows NT SP2,Windows 95,Windows NT,Windows 2000 SP2,Windows 2000
License: freeware
http://support.dell.com/support/downloads/index.aspx? here you will find your solution
Apr 14, 2009 | Dell Dimension 4600C PC Desktop
Dell Dimension 4600C won't turn on
Unplug the unit. Re-seat the Memory and Daughter-boards. Plug in and try to start.
Nov 22, 2008 | Dell Dimension 4600 PC Desktop
Trouble removing case on Dell Dimension 4600c
Try this...
I work on these systems on a weekly basis and they can be very difficult to open. I would make sure that you have already removed the feet from the bottom and turn it so that the heavy side (technically right side up) will be facing the floor. Place the palm of each of your hands on each of the buttons and squeeze the system as hard as you can while holding the system maybe an inch or two off of the floor. The plastic buttons basically cover a metal release tab that is actually part of the frame. All of the clamshell type cases are tough to open because of this. Good luck.
Apr 24, 2008 | Dell Dimension 4600C PC Desktop
Dell Dimension™ 4600C PC Desktop Logo
1,193 people viewed this question
Alun Cox
