Question about Necchi 3101 Mechanical Sewing Machine
Plastic casing around the bobbin
I tried to change thread in the bobbin case, and when I removed the bobbin a red plastic piece fell out from inside the case. I can't figure out how to fit it back in.
  • 1 more comment
  • lynnhorrigan Jan 31, 2009
    Thanks for the time to reply, My husband and I sat and got it figured out after going through the manual. It was easy enough, but not something I could figure without the book. It was part of the bobbin case that just clipped into the machine and helped hold the bobbin. It will be going out to be serviced on Monday. Thanks again!
  • SewTechWayne
    SewTechWayne May 11, 2010
    Is it about 1" long and curved? If not please describe.
  • talk2ginny
    talk2ginny May 11, 2010
    Hi - have you tried to put the bobbin back in the case without it? Do you have a manual that describes what the piece does?
    I'm not familiar with your machine, but you could try searching the web for your machine's name and model. I have found several troubleshooting sites for older machines. You could also purchase a new bobbin case - just be sure the bobbin case is compatible with your machine. I have an extra bobbin case for each of my machines (I have several older sewing machines). If the tension on one of my machines goes "wonky", I replace the bobbin case, and if the that fixes the problem, I throw out the old one. Saves time and money and prevents damaging your machine.
    If you have had your machine for more than two years but have never had it serviced, it would be a good idea to take it in for a tune-up. If you do take it in, ask exactly what is included in the tune-up. I've worked for two different sewing machine dealers. One was very reputable and had an excellent technician. The other was not. So make sure you know what you are getting for your money.
    Good luck, Ginny
The red plastic piece sits adjacent to the inner metal piece with the sharp hook assembly. It does not sppear in the drawings in the manual. There is a cutout at its center that fits over the metal head protruding from the inner metal piece. When placed correctly you can see that the red piece fits precisely into the circumference of the metal housing in which it rotates. The outer metal piece is secured by the two black swing arms and the bobbin can then be easily replaced as usual. It helps to tilt the machine back slightly when inserting these pieces but be careful not to lose the red plastic piece inside. If it drops in it can be retrieved with a pair of needle nose pliers or similar.
Posted on May 27, 2012
    New Friend:
  • 186 Answers
That piece is a sweep that helps keep the hook clean. It is not necessary for the machine to use, I have thrown away many of them. If you can get your hook put back in you should be ready to go.
good luck!
Posted on Jan 31, 2009
Why is the hand wheel so tights
It shouldn't be too tight. Clean out and remove the bobbin/bobbin case. Now, try to turn it. Does it turn any better? If it does turn easily without the bobbin case and bobbin installed you know the bobbin case was out of adjustment.
To adjust the bobbin case reinstall the bobbin case. Slightly move the hand wheel back and forth. There should only be slight movement of the bobbin case. The bobbin case is held in place by a small piece of metal next to the bobbin case.on the lower right corner. Just make the adjustment to prevent the case from movement.
The hand wheel can also be prevented from movement due to the interior parts of the machine being filled with dried greese. If you're feel safe about this you can remove the front, back, etc and inspect for buildup. Clean it up with carburetor cleaner and a qtip. Try not to douse the plastic gears with this. Clean it thoroughtly. Put sewing machine oil on all steel against steel movement. Any plastic movement should be done with a non petrolium product like silican spray. You can move the hand wheel a great deal to observe any parts that may have movement probmems.
Jul 08, 2017 | Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
Bobbin case is dislodged and keeps rotating in the assembly
You must make sure that the case is resting against the silver spring at the bottom and slightly to the right. The part of the case resting against that spring prevents the case from rotating. There should be a red fuzzy piece on your bobbin case, and that belongs at the top underneath the feed dogs. Also, you must have the plastic cover on when you sew or embroider--it prevents the bobbin from jumping out. Your manual actually has a drawing of the correct position for your bobbin case. It also shows you how to thread your bobbin case; it is important to keep your hand on the bobbin so that tension is applied to the thread while you're threading it. It is easy to not get the thread in the "eye" on the left side of the case if you are not exerting tension on the thread. If you cannot find your manual, a PDF version is in a directory entitled "Manuals" in your Futura software on your computer. I'm attaching a photo; this is actually a photo of the Futura XL case, so there is no red piece (which is meant to cut down on lint from the thread, by the way), but otherwise it is the same. ac4233a9-1a5e-4ef2-b599-69270028ce57.jpg
Dec 03, 2013 | Singer CE-200 Quantum Futura Computerized...
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
I have a janome 1 step sewing machine and it keeps jaming. I have been sewing a thicker fabric recently with no problems, but now it jams after about 3 revolutions. I think something is wrong with the...
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, I think yours has a top loading bobbin inside a magnetic bobbin case so this info should work for your model. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room to work).
PLEASE NOTE: If you've never pulled this bobbin area apart before, good idea to snap pics with your digital camera as you go to refer to and for reference next time!!
This uncovers the bobbin holder area, you'll see there is a black plastic holder which your bobbin goes into which has the tension device on the side and this then sits inside an outer metal casing which is the hook race. The bobbin holder is held there by a magnet underneath it and sits up against another little stopper. Look at the bobbin case and the stopper, there should be two red marks that must line up. Are they???
If the answer is no, then you need to remove the bobbin case, clean out any lint and fluff using your little brush that came with the machine, and you may also have pieces of thread caught in here too. Once clean, place the bobbin case back into the outer surround, under the other piece and lining up the two red marks. This is where photos are so helpful.
Now replace the needle plate and screws, pressure foot, pop in a new needle and thread everything up again.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've pierced it with the needle several times.
I hope that this helps you out, good luck with your machine.tally_girl_3.jpg
Apr 13, 2011 | Sewing Machines
When the machine starts the bobbin shifts, instead of stitching it jams. I have tried to replace it but I don't seem to be having any luck. Elna 6003 quilters dream
Sounds like the bobbin case has shifted inside the rotary hook area. Have you got the manual? if so, does it give directions to remove the bobbin case as part of the cleaning instructions? If you have never taken it out, perhaps take pics with your digital camera to help you put it back in correctly. It is held in by a magnet underneath it. Remove the needle plate, pressure foot and needle, and the bobbin.
Have a good look at the bobbin case, it should have a stopper which sits against a little bump and might have two red marks to line up correctly. Are these lining up or has it shifted a little. If so, then lift out the bobbin case by holding the edge closest to you and lifting it upwards and towards you. Brush the underneath area out carefully to remove any lint or thread bits with your little brush bringing the lint out of the area and into a bin (dont push it around into the area under the rotary hook) and don't blow it out with air. Have a good look at the bobbin case too and check it for any damage, if you dislodge it while stitching the needle can strike it and as its plastic there may be little marks or bits of plastic now, if so, give them a gentle rub with fine grade sandpaper (away from the machine works) or a nail file to smooth off. I found that mine had a couple of holes and the thread was then catching on the rough edge of plastic and jamming constantly. I actually bought a new bobbin case after 3 goes to sort this out.
Now put the bobbin case back into place, lining up the red marks if it has them. Manually turn the flywheel towards you through a stitch sequence, the holder should sit still while the hook goes around it.
Reassemble the machine, rethread and test sew. I hope this helps, if you have tried all this already, then perhaps take it to your Elna dealer for further investigation/service.
Apr 05, 2011 | Elna Quilter's Dream 6003Q
Bobbin case making noises and bobbin thread keeps breaking the material also pukkers up underneath
Do you have a manual for this machine? You need to follow the cleaning instructions and remove the needle plate, and clean under the bobbin holder. I've attached an image from my Janoma 6500 manual, it looks very similar to this Elna so I'm thinking its the same design bobbin and race. There may be a little triangular shaped tool in your kit but any short flat blade screwdriver will remove the two setscrews. (always good idea to unscrew off the pressure foot and take out the needle first so you've got room).
Mar 07, 2011 | Elna Xplore 8600 Computerized Sewing...
The thread seems to be getting caught under the plate on something.
If the thread continues to catch then you may have managed to damage the bobbin case; as they are plastic if they move out of position the needle can catch and burr or pierce them. If this has happened you could try to smooth out the burring with an emery board or similar. Or you may need to replace it if damaged badly. I've changed mine twice so far because I've damaged it badly.
tally_girl_0.jpg I hope that this helps you out, good luck with your machine.
Feb 17, 2011 | Elna 7200 Computerized Sewing Machine
I want to adjust my bobbin tension on my 230 viking sewing machine but I don't know how.
1. remove the clear bobbin cover
2. slide the needle plate towards you and remove it, do not pry it upward or you'll break the gray plastic housing that supports it.
3. remove the gray plastic piece that is on top of the black bobbin case.
4. remove the black bobbin case from the machine.
5.Look on the side of the bobbin case for a small hole with a screw deep inside of it. That is your tension screw. Turning it to the right increases the threads resistance and left loosens it.
You know you bobbin tension is in the right range with the following test: Have your machine in the ready to sew positon. Meaning the bobbin has thread on it and it's in the machine and the bobbin thread is coming up through the needle plate. Gently pull on the bobbin thread to feel the amount of resistance. It should be slight not tight. If you pull on the thread and feel a light resistance your problem is not your bobbin. If you have looping on the bottom of your fabric, the problem is the top thread.
Dec 27, 2009 | Husqvarna Sewing Machines
Want pick up my bobbin
re-thread the top thread
when putting in the bobbin, make sure you put it in right,
hold the bobbin between you thumb and first finger of your right hand when you pull the thread with left hand it should rotate the bobbin counter clockwise.
If you run your machine all day you need to clean under the bobbin case,
Take the cover plate off, take out the bobbin case and clean under, i take a q-tip with machine oil and rub around the inside of the metal case and around the bobbin case,
replace the plastic bobbin case making sure it's in right, turn the hand wheel by hand, the case should stay still and the inside will move, the needle should not hit anything
put all back together and try again
if the bobbin turns clockwise you are going to have problems
if this helps please rate it
thanks,
good luck
moni
May 09, 2009 | White Sewing White 4400 Computerized...
Necchi 3101 Mechanical Sewing Machine Logo
156 people viewed this question
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
