HP W1907 Monitor goes black after resolution change
When any game changes my screen resolution, my monitor goes black. If i wait a couple of minutes and then turn the monitor off then on the monitor is ok.
Re: HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining. Regards, Asitomani
This sounds like a power board problem. Could be failing power capacitors, which are allowing the charge to leak ( stripping the screen, not recommended) will show bulging or leaking capacitors). Or it could be an issue with the PCB. The fact it will restart once it has "cooled down" points to this.
I'm assuming you have tried the monitor on a different computer, just to eliminate the graphics card (unlikely but worth a go)
Solution..get it checked by a qualified TV repairman, it may a be a simple fix.
If this monitor (HP w1907) is going into sleep mode the normally blue power led will change to yellow. This indicates loss of video signal or possible out of range resolution. If the picture goes dark and the power lite stays blue, you have a backlight malfunction. It can be an inverter power fault but this model mostly has worn out backlights causing a shutdown condition. Monitor Mike
The picture board on your monitor is faulty or bad, since
it goes
black after few minutes, it means the
board of your monitor has developed fault.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity
to help with the replacement of the picture board or any service center
because the fault is not something you can fix yourself. in order not to
complicate issues.
First place to check will be the power supply section, look for bad caps with bulging top or bottom seal, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen. Check the inverter output/inverter board and you maybe able to get parts from www.lcdparts.net
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem.
If it doesn't just try some other resolutions until ou find one that works.
I hope this helps,
Yannick.
This is normal. BUT it should only do this while launching, once it hits the main menu clearly. It should be fine.
2. If you alt tab while the process is running, you may see the resolution change. But if you close it properly than it should not change except for those reasons/times.
Contact me if none of those do work, Regards, Asitomani
