Question about D-Link AirPlus DI-614+ Wireless Router
Power sign on everything.
When i plug in,
the light is on below WAN , 1,2,3,4
but i did not put anything in behind it
  • 36 Answers
Reset your router to factory defaults. usually by
unplug router presss and HOLD the RESET button, do not release button PLUG router to turn on wait 30 seconds. release reset button wait 1minute turn off router. turn on router. wait 1minute and try to configure router via setup wizard use the CD if you have
Posted on Feb 02, 2009
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
I accidentally change my mac address in the router... now i dont have internet connetion..... how can i change it back... w/o accessing in the internet.... please respond...
If you are connecting the router to a cable DSL satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem's power adapter. Shut down your computer.3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the WAN port on the router.4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.7. Turn on your computer.8. Verify the link lights on the router. The power light, WAN light, and the LAN light (the port that your computer is plugged into) should be lit. If not, make sure your computer, modem, and router are powered on and verify the cable connections are correct.9. Skip to page 16 to configure your router.Connect to Cable/DSL/Satellite Modem OR
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having ftp://ftp.dlink.co.uk/dir_products/dir-600/manual/DIR-600_B2_Manual.pdf
Aug 27, 2011 | D-Link DIR-600 Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
D-Link DI-534 Starting up problems
Try resetting the router . Press the reset button for 10 seconds and after 10 seconds unplug the power cable but continue pressing the reset button for another 30 seconds after 30 seconds plug in back the power cable and continue pressing the reset button for 10 seconds and release it after 10 seconds.
try to open an Internet browser and type in 192.168.0.1 on the address bar. It should give you the DLink page. Once you have that configure your connection.
Jan 08, 2009 | D-Link AirPlus DI-524 Wireless Router
Wont connect to internet
You need to reset the router if the lights are flashing. Press the reset button at the back of the router for about 20 seconds then release it. Now unplug the power for 20 mins as well and plug it back in. Make sure your connection is right. PC connected to port 1 and modem to WAN or Internet port.
Dec 17, 2008 | NetGear WGR614 Router
No connection with router
This may be a lengthy description, but I just wanted to be as forthcoming as I could, as I was annoyed by the lack of support I was able to find to fix this problem myself. As far as I understand it, the problem is in the router. I don't know what it "thinks" it's doing, but the solution detailed below will essentially just tell it to do the basic things it should be doing.
What I had to do to fix this (Same router model, same issue) was to unplug every cable from the back of the router (including the cat-5 cable coming from the modem and going into the WAN port), except for the computer that I know works when plugged directly into the modem. I left the modem turned on, though disconnected from the router.
The point of this was to have a simple connection between computer and router so that I could get into the router and tweak its settings. For some reason it was freezing up on me when the modem was plugged in and I could not access the router at all. So, after plugging in only this computer to the router, I unplugged the power to the router, waited about a minute, and plugged it back in. When the router first turns on all of the lights on the front come on. Wait for all of the numbered ones to go off (by 'numbered' I mean the lights numbered 1-4 on the right side of the front panel display) except the one that corresponds to your computer's connection port in the rear of the router (the number your computer is plugged into).
Once this has happened you should be able to get into your router through a web browser by putting "192.168.0.1" (no quotes) into the address bar. The default username/password combination (which you should be prompted to put in) is "admin" for the user name, and leave the password field blank.
You should now be viewing the router's page, which should by default be showing the "SETUP" tab. If we cant fix the router by renewing your DHCP (as detailed below), then we will return to this page.
For now, plug the cable from the back of your modem into WAN port on the back of the router. Click on the "STATUS" tab (3 buttons to the right of SETUP), and look under the "WAN" heading. Note that the settings (I'll refer to them as "WAN Settings") displayed under this heading are as follows:
MAC Address
Connection
IP Address
Subnet Mask
Default Gateway
DNS
If it says "Connection : DHCP Client Connected" and there are numbers besides just zeroes for the lower WAN settings, then your internet should be working. Verify this in a new window by attempting to browse to your homepage or google or something. If it does not work, or if the Connection status is not connected, then click the "DHCP Renew" button directly to the right of the "Connection" setting.
A number of things could happen here. If it works, the WAN settings should no longer display only zeroes (you may have to navigate back to this page). If the DHCP renew attempt times out or doesnt work, then navigate back to the "SETUP" tab on the main page of the router (the page we started on).
There should be a button in the middle of the page under the "Internet Connection Wizard" heading labeled "Setup Wizard". Click it, then click it again as it changes to "Launch Internet Connection Setup Wizard". The four steps are:
  • Step 1: Set your Password
  • Step 2: Select your Time Zone
  • Step 3: Configure your Internet Connection
  • Step 4: Save Settings and Connect
For the "configure your internet connection" step, click the button that copies your MAC address. At the end of this process your router will be reset. Again, wait for the lights on the front of the router to display properly before signing back in. You will have to sign back in afterwards using your new password (admin should still be the username). At this point it worked for me. If it is still not working, go to the STATUS page again and renew the DHCP (same step as before) now that you have run the setup wizard. Good luck, hope this solves it for ya!
Aug 14, 2008 | D-Link 802.11g Wireless Router WBR-1310...
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
DGL-4300 resets every few seconds
Try the following:
1. Hook up your router like you want it to be
2. After the WAN/Wireless lights turn off we want to HARDRESET your router.
3. There will be a small hole that requires a pen or paper clip to press...Hold this down for about 15 seconds, or untill the power light flashes on your router.
This might take care of it.
let me know.
Jan 10, 2008 | D-Link GamerLounge DGL-4300 Router...
Router not working at all
This is a problem with the router, those signs are just telling you that the router has some problem, try to press and hold the reset button for 30 seconds and after that unplug the power of the router and run the setup CD for it to reconfigure the router...
Jan 04, 2008 | Dynex DX-E401 Router
DLINK Router
kmkm:
Is this the WAN light you are talking about or the power light?
The WAN light blinks to show you connection with your client computers. Its ok.
If its the power light then un plug router completly and plug it back in check if does the same thing again? If yes then some hardware issue exist and the router needs to be replaced.
Hope that helped!
Dec 07, 2007 | Acer D-Link 2.4GHz Wireless Router 802.11b...
D-Link AirPlus DI-614+ Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
