Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Toshiba 46h83 tv projection not full orizontal pic
My toshiba tv does not display the full width of the screen. it is concave on either side and like not in focus...please help
  • matt crandall Aug 01, 2007
    Yea this sugesstion was not what i was looking for, I obviously know how to set picture size on the tv, and know what widescreen movies are. This is a actual problem with the TV that I was looking for not a problem with me.
  • planetfunk44 Apr 29, 2009
    Mine is just the opposite of yours, my pic is too big
How do I reprogram the remote?
Posted on Apr 08, 2009
If you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Posted on Jul 30, 2007
SOURCE:
Touch focus
I think the screen adj is too high on one of the screens.
How and where did you touch focus?
www.aaatvservice.com
Aug 09, 2014 | Toshiba 46H83 46" Rear Projection...
Have vertical lines across the tv. Started as something that happened right when I turned the tv on (for 5 mins or so). Now it's all the time. Toshiba 46H83
you more than likely have a bad panel inside of your tv. you can have someone repair it but it's not recommended as it's pretty expensive. You should just invest in a new tv.
Jul 23, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Can you connect macbook to Toshiba 46H83 projection TV
"This TV is not intended for connection to and should not be used with a PC (personal computer)". This statement should say it all.
Dec 19, 2017 | Toshiba 46H83 46" Rear Projection...
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Jun 10, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
May 13, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Problem with vertical
Is the left side normal? Side(s) cut-off,out of view might be a HV
width problem or a regulation trouble.Vertical adjustments will
not help---Horizontal width might----be sure to put the value back to what it was if change does not help.
Oct 12, 2007 | Toshiba 46H83 46" Rear Projection...
Horizonatal lines on Toshiba 46H83
If the repairman you had look at the set is used to working on projection sets, have him come back and Re-Solder Connector Px801 (Edge Connector) On The G-Hyper Module. (Pins 1 And 2 Of Px801 probably needs to be Re-Soldered) Otherwise, find a different repair person.
Dec 19, 2006 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
