Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25SGRE side by side water dispenser...
Stopped dispensing water. Although, the ice maker still makes ice and we have replaced the filter.
  • 1 more comment
  • baum314 Jan 31, 2009
    very similar problem; I recently changed water filter; worked fine. Ice maker works, but water dispenser doesn't. I don't want to start taking freezer door off, but how do I get water dispenser to start working again?
  • Anonymous Mar 20, 2009
    water dispenser wont dispense. you can hear the relay click when you press the button, but I can't tell if the line is clogged, or if the motor is coming on. Does anyone know where the motor is?
  • Darwin Mar 20, 2009
    mine is not doing anything. the lights are on, but when you try to get ice or water they blink a few times.
    I've reset the filter, emptied the ice, turned off the power for a minute, but no response so far.
    is there a reset somewhere?
The same thing happened to me. If you pull the refrigerator out and remove the large silver panel, you will see the water lines on the left. The line going to the ice maker was fine, but the line going to the water dispenser was split. You may have the same issue.
Posted on Feb 05, 2009
I paid $100 to have a service man pull the back off the refrigerator to tell me that the line was frozen. Someone put the freezer temp very low. Pulled plug, cleaned out refrig. Plugged in after 4 hours, Refrig has worked fine since then, ice maker works, water dispenser is fine.
Posted on Mar 30, 2009
Check the plastic "s" shaped piece that is mounted to the back wall of the inside of the refridgerator to see if it is froozen. That is where the water for your dispenser is cooled prior to being dispensed. If it is froozen, then you may try adjusting the temperature.
Posted on Mar 29, 2009
Why doesn't my refrigerator water dispenser work?
Just like in the ice maker, you will find a solenoid valve.
If you hear the valve click open and close when trying the water.
If you do not here the valve open and close, check the switch and valve.
May 19, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Can water/ice dispenser be fixed without replacing door
Go to www.repairclinic.com and enter GSS25SGRSS. With luck, you will be presented with a list of common replacement parts/assemblies and will be able to determine whether the dispenser is available as a separate assembly.
Nov 08, 2017 | GE GSS25SGRSS Side by Side Refrigerator
I possess a GE Fridge model No. PCG23NHSBFBB (2 years old)and although the water dispenser is fine, the ice maker has stopped making ice cubes (the the dispenser tray has no ice in it)
i guess the ice try is completely dry.. this tells me that your solenoid has gone. unfortunately the only way to fix it is to replace the solenoid.if its not the solenoid it will be your water pump. both will require a technician, hope this helps
Nov 11, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator Ice maker not working
my ge refrigerator stop making ice a week ago, water dispenser still works.
May 15, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Ge monogram water line
the water dispenser does not dispense water, although i can hear the motor running, but water is reaching the ice maker.
any tips?
You may have a clogged water line or filter something blocking the flow of the water or you may have to replace the filter or a water line – it may have a defective sending unit / pump and it would be wise to check it out with a regular service tech and to also check your owner’s manual for troubleshooting.
Apr 14, 2008 | GE Monogram® ZISS420DMSS Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
683 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
