Question about Nokia 6600
Charger problem Hi I have a 6600 nokia ,the charger is not working,why...
  • 50 Answers
Simply the condition of the charger is bad.Buy a new charger or have a expert look it over.
Posted on Jul 29, 2007
SOURCE:
How can i power a nokia 6600 or 8210 directly from a charger without a battery
Hi christoph83048,
I am afraid that procedure is not possible for any Mobile devices, including your own as the battery is required.
I Hope this helps.
Jun 19, 2011 | Nokia 6600
When i power on my nokia 6600 phone the display light on and then a few seconds off. can you tel me the solution?
Most probably, battery of your nokia 6600 phone is not holding charge. Generally battery becomes poor / unserviceable after 3-4 years of use.
Also check whether charger of your nokia set is ok. Poor/weak battery shows this symptom which needs to be replaced.
Good luck and good day.
please do rate the solution if it helped you.
Aug 19, 2010 | Nokia 6600
Fommat mobile
to format the Nokia 6600 , you can do a hard reset ( The phone’s setting will be restored )
to do hard reset:
simply enter the code : *#7370#
Then it asks for security code default is 12345
Note:
-before do any reset, you better take a back-ups of your data
-connect to the charger while resetting, this will avoid of running out battery and make your mobile become usable
Apr 15, 2010 | Nokia 6600
Not starting my nokia 6600
Check the power button of your Nokia 6600 if it is working properly. Also, check the battery if it is providing power to your phone, or it is empty. Lastly, check your battery charger if it is charging the battery. Replace parts when needed.
Oct 18, 2009 | Nokia 6600
Nokia 6600 bluetooth promblem
Please restore the factory settings by pressing *#7370# it will ask for your security code (default 12345) enter it and proceed. Phone will restart. It will take a while to restore settings so please be patient. Once restored your phone's bluetooth should work just fine.
Important: Make sure phone's battery is fully charged (or keep the charger plugged in) before performing the above operation.
Feb 09, 2009 | Nokia 6600
Nokia 1600 not charging problem
try cleanning the batter leads on the battery and on the phone. then try to charge. if it didnt work, try using another batter or charger, if all that didnt work then, there's something loose in the charger circuitry of the phone, send it to a service place to solder it for you.
Jan 03, 2009 | Nokia 6600
Nokia 6600 wont start up
it is a software issue on the phone you need to take the phone and have the firmware reflash in the phone to get it up and running again as usual.......any mobile repair shop in your area should be able to do that for you.
Dec 02, 2008 | Nokia 6600
Nokia 6600 ''not charging''
you should try a new battery
Nov 23, 2008 | Nokia 6600
Nokia 6600 - mic stopped working
Why nokia 6600 is stopped from manufacturing?
Nov 04, 2008 | Nokia 6600
NOKIA 6600 wont charge and turn on
hey,
how about check your charger .. maybe there is a problem with your charger... try another nokia charger
Cheers
Aug 28, 2008 | Nokia 6600
Nokia 6600 Logo
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
