Question about Philips Magnavox 51MP392H Rear Projection Television
Tv wont come on off and on light wont light up
51 inch phillips hdtv wont come on electric was off cam back on tv worked good then about 1 hour the tv went off i have nothing now
  • 164 Answers
Does the outlet still work?
also, for safety sake, reset your circuit breaker.
let me know...
Posted on Feb 18, 2009
I have a 52 inch projection hdtv. every time I
Well basecally Samsung most comont parts that go out are,
LAMP: The generic lamp will go from 3500 to 4500 hours and a phillips lamp will go for 6000 to 8000 lamp hours,
How It Works The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp. The lamp works with the ballast to project light into a light engine that separates the colors of the light, then recombines them with an image. The image is then reflected on the back of the TV and then onto the screen. But you need to listen carefully for any strange noise like (CLIKING,HUMMING,BUZZING,WHIRLING SOUNDS) that will help younarrow down whats is wrong with yor tv bacuse the BALLAST wich is the board incharge of sending the correct amount of current to your lamp could be weeek and will not power up you will hear a cliking or electrical huming Also the color wheel is a commont part that goes out on Samsung and that will give you a vibration and a loud whirling sound,you can get more help and real good prices at good luck and keep us posted
Nov 12, 2009 | Televison & Video
Reset lamp hours on sony grand wega
  1. Press "Display" on the remote, followed by the 5 button, then the sound up key, and "Power On." Do this while the TV is in Standby mode.
  2. Step 2 Then press "Jump" 3 times to enter the DE Service menu. The TV screen will display the total lamp time hours.
  3. Step 3 Reset the lamp time by pressing channel 3, then mute, then enter. This will put your lamp counter back to 0.good luck
Nov 05, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
Phillips 42 inch LCD 42PF9730A Redlight flashing
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 16, 2009 | Philips 42PF9631D 42 in. Plasma Television
50 inch phillips hdtv model:50pl9126d/37, no picture...
Unplug for one hour then plug back in---worked for me--computer resets
Mar 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My phillip 51 inch will not turn
this happened to me once i think the problem is that the button is used so infrequently that it sticks try pushing it very hard as many times as needed and id and when it comes back on dont use the button anymore just stick to the remote
Feb 14, 2008 | Philips 51PW9303 51" Rear Projection...
T.V. won't turn on
PCB repair should be done by a qualified tech. Your problem could be HV cap bad,xformer defective or bad connection problems and pico fuse open. Check 2KV cap near xformer.
Sep 26, 2007 | Sony KP-51WS520 51" Rear Projection...
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips Magnavox 51MP392H Rear Projection Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
