Question about Brother CS-80
Needle post stuck
Brother innovis 4000D - was used as a demo machine for about  a year and then stored in a closet - was given to me recently.
I was sewing straight stitch - the needle got stuck in the down position the hand wheel froze, an alarm went off and a safety error message came on the screen - I removed the needle with tweezers as I was unable to raise the needle post.  The machine is still frozen and I cannot find anyway to unlock it out of the safety lock.  I have removed all thread - cleaned around the bobbin area removed and checked the bobbin case. The hand wheel will not turn manually.  Is there any way to unfreeze of is it strictly a tech type problem. My nearest repair place is a 2 hour drive away.
  • Katie Roser Jan 31, 2009
    Brother Innovis 4000D - needle post got stuck in the down position while sewing velvet with a straight stitch. I was unable to turn the hand wheel - it locked up. An alarm sounded and safety lock error message came up on the screen. I could not remove the needle and fabric as all was locked up, so I loosened the needle and pulled it out with tweezers. I then removed all thread and bobbin - cleaned out the bobbin case and took it out to make sure. Turned back on and the same thing it will not unlock - I unplugged for two days and went back to it -still locked and the needle post is still stuck down - safety error comes on. The green light comes on but if I push the lift needle button the alarm goes off again, the post shakes and the safety error pops up again.
    thank you!
  • 360 Answers
With no thread in the machine and the bobbin case removed (ensure there are no remnants of thread in, on, or around the bobbin area), turn on the machine. If you get the error screen that deals with tangled thread, press close on the touch screen. if the error screen goes away, lower the pressure foot and press the start/stop button (This will require thread tensions to be reset before using the machine). If this unlocks the machine, all should be fine, if not repeat the procedure once more. if fault still exists take the machine to a authorized repair facility.
If you don't have the owners manual for this machine, you can download it here.......click here
Thanks for using Fix Ya, please take the time to rate this solution.
Posted on Jan 31, 2009
    Scholar:
  • 124 Answers
I would unplug the machine and let it sit for about 40 minutes so it can "reset" then plug it back in. It should work after that.
Thank you for using Fix Ya!
Good Luck!!!
Don't forget to rate the overall satisfaction of this answer.
  • 10,594 Answers
In my opinion its better to take it in Brother repair shop and Brother qualified tech will fix it properly.
  • 837 Answers
Have you tried unplugging it for at least 30 minutes?
Brother innovis 4000D. Start stop buttons stuck in red, Machine beeping and screen light but blqnk
If your machine was serviced before purchase and now doesn't work, return it to be re-serviced and made functional.
Jul 05, 2016 | Brother InnovIs 4000D Computerized Sewing...
What memory stick will work on a innovis 4000d brother embroidery machine
Most memory sticks will work, but the smaller capacity sticks work the best.
If your stick has a lot of designs on it, the machine must read all the designs before bringing up any on the screen. Only keep a few on a tick at a time.
Sep 23, 2014 | Brother InnovIs 4000D Computerized Sewing...
Malfunction error PF-PM on Brother Innovis 4000D. HELP!!!
try unplugging it and letting it rest for 20 minutes? Sometimes that will reboot it.
Dec 10, 2013 | Brother InnovIs 4000D Computerized Sewing...
Twin needle tension problem
Hi, Tania
Chances are that you're using a universal point twin needle, designed for sewing on woven fabrics. Twin needles also come with a ballpoint which is what you need for knit fabrics
A ballpoint or stretch needle has a rounded tip that will separate the knit fibers as it penetrates the fabric instead of breaking through them. A universal needle may not catch the bobbin thread on both needles when used on knit fabrics; this is necessary for proper stitch formation.
Nov 06, 2012 | Brother InnovIs 4000D Computerized Sewing...
Brother CS-80 Logo
47 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
