Question about Reddy Heater-30-55,000 BTU Variable
Fractionalhpmotor what is the availability on a suitable motor to replace the original 1/5 hp motor on my reddyheater55
  • 181 Answers
Motors are still avalible for that unit, part number is 102001-01 .they run between $80.00 and $110.00 i hope that helps.heres a link to parts. www.portableheaterparts.com
Posted on Mar 02, 2009
How do I get a wiring diagram for motor model 370200
There should be a wiring diagram under the connection cover plate that tells how to connect wires for both 115v and 230v service.
By the way, any motor of any brand with a #56 frame and 1 hp or better that runs at 3450-3600 rpm should be suitable for use on a table saw. 1.5 hp would be better. (I upgraded mine to 2hp)
Harbor freight has a suitable 1.5hp replacement motor for $140.
Depending on the motor you get, you may have to buy a pulley at the same time to match the shaft diameter and blade rpms.
Sep 25, 2014 | Saws
Do you know the specs. on motor of craftsman 10"tablesaw model 315228410
Is there a nameplate on the old motor? If so, it should state the HP, speed and direction of the original motor. If not, a 1/2 HP to 1 HP 1750 RPM motor with the same size shaft that will turn the blade the same as the original should work fine. From the online manual, it appears to have an internal start switch, so the wiring should be standard.
Jun 22, 2014 | Craftsman 10" Table Saw
Replacing bearing whisperflo wf-26 1 1/2 hp motor
no bearings available need to replace motor dont forget the seals
May 17, 2014 | Hayward 1 12 Hp Super Swimming Pool Pump...
Pool Motor problem
depends if flow is ok if not replace with same size
Jun 20, 2013 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have an old Craftsman bench grinder that I got at an auction. I need a capacitor and the one on it has no markings. It is a 1hp model 319.19063. Sears Parts direct says that it is no longer available and...
this is a "Split-Phase"motor it uses only a run capacitor and a typical capacitance rated MFD rating will be between 80 and 290 MFD, go to www. grainger..com and they will have your part,and even if its an older unit and the model/serial/number is available take it with you & they will have a replacement capacitor available in the correct size/dimension/mfd/etc
Apr 24, 2011 | Baldor 8" 1 Hp Electric Bench Grinder
I have a NorthStar pump. The motor went out so I have it replaced with a different manufactured motor (WEG). Same HP and even a higher SF factor than the original. The new motor draws 10 amps (rated is...
THATS WHAT YA GOT 2 DO ..SOUNDS LIKE YOU HAVE THE WRONG MOTOR .9.6amps IS A 1 1/2 HP ... A 1HP IS 7.6amps.. SO A QUICK FIX WOULD TO GET A 3/4 HP IMPELLER , THAT WILL GET YOU BACK IN THE NEEDED HP RANGE .. welcome to the HAYWARD NORTHSTAR .. HEY IF'N I WAS ANY HELP COMMENT OR VOTE ..JAY
Aug 19, 2010 | Hayward 1.5 Hp Northstar High Performance...
Pump gets very hot when it runs
WARNING when replacing a motor on a northstar you must match the hp and service factor.. say its a 1.1/2 hp motor and the service factor 1.47 you will need a 2hp with a 1.15 service factor to replace that original motor .if you replace it with a 1 1/5 motor it WILL BURN UP THE MOTOR !!. welcome to the hayward northstar .
only the 2 speed motors have a start switch the CAPACITOR would be my first check it may be a 30 or a 35uf at 370 cap LOOK IN YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING USE YOUR ZIP CODE IN YOUR SEARCH
Aug 05, 2010 | Hayward 1.5 Hp Northstar High Performance...
Need replacement motor for a model MMB10B
Unless you can find an HVAC shop with a NOS motor for this unit you will not find a drop in replacement. Even if you do get lucky and find a NOS motor be prepared to pay nearly as much for it as you would a whole new evap cooler.
That said, there are motors out there that will work, but you're going to have to make them fit with custom mounts.
It's still a little spendy, especially if you want two speeds like the original motor had, but you can get out for $80 or less if you're willing to settle for one speed (on/off).
boatandrvaccessories.com has a "Packard 40066" compressor motor for $69 plus $13 shipping. It may work but has only one speed.
Basically what you're looking for is a "48 frame", 1/8 hp, direct drive, 110-120v, 1075rpm, 1/2" shaft diameter and around 3" in length (to give you flexability when mounting), "totally enclosed" or "open drip-proof" housing (NOT "open"). Rotation can be either CW or CCW as you can mount the motor on either side of the housing and some motors are reversable. If you've got the skill to custom make some mounts then you can probably fudge some of these specs. The ones you can't change are the 1/2" shaft and the RPM. Do not exceed 1075rpm. The blower assembly simply can't be made to go much faster in that housing and if you try you will overheat the motor and burn it out very quickly (trust me on this one!). Most of the cheap motors I've found are 208-230v and I just don't see the point in having a small 220v PORTABLE evap cooler, that's just dumb.
After a LOT of online research I've found the following motors that would be a suitable replacement, with all the above mentioned specifications. I'm sure there are more, but cross referencing this information for someone not in the business is tricky and time consuming.
AdobeAir 1/8 HP 115V Motor for Adobe MMB10A RF031095 $116.66
http://www.comfortgurus.com/product_info.php/cPath/25_142/products_id/7451
Emerson 4856 (k055srj4796722b) (www.emersonmotors.com)
A.O. Smith 136A (UH1036NB) (www.aosmithmotors.com)
Magnetek 136 (now owned by A.O. Smith - www.aosmithmotors.com)
Fasco D733 or D261 (fasco.com)
Marathon X924 (www.marathonelectric.com)
AdobeAir RK232A check acehardwaresuperstore.com
Emerson K55HXKZT-9867
Grainger.com is a good resource but they are expensive.
The motors listed are suitable replacements, but have only one speed, "ON" or "High".
Packard 40066 - 115v 1075rpm $69 - SINGLE SPEED
A.O. Smith 321P177
A.O. Smith 323P077
A.O. Smith 323P487
A.O. Smith 323P490
A.O. Smith 323P677
A.O. Smith U6521
A.O. Smith UH1016
A.O. Smith UH1026NB
A.O. Smith UH9034
A.O. Smith US1016
A.O. Smith US1016NB
A.O. Smith ORZ1026
Brownell MTG3206
Century C045A
Carrier HC37DX120
Emerson 9034
Fasco D834
Franklin 8736010170
Franklin 8715810230
Franklin 8735810180
GE 3081
GE 3206
GE 3950
Grainger 3M658
Grainger 3M800
Grainger 3M828
Grainger 3M829
Marathon X302
Mars 03950
Packard 70066
Packard 40066
R.E. Michael 1E521
Reznor 55682
Reznor 64678
Rotom R12177
Rotom R12834
Rotom UH9034
Trane MOT6195
Universal U136
Universal U177
Universal U380
Universal U566
Universal U730
Good reading for selecting a replacement motor:
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=13100
I suppose that if you found a smoking deal on eBay for an "Open" type motor you could try it, but I doubt it would last long and make damn sure that ****** is grounded well.
Aug 07, 2009 | Mastercool Portable Air Conditioner
Would a 2N3055 make a suitable replacement for a 2SC1667 transistor? The 2SC1667 is from a Leak reciever - the main amp section they are used as the main amp.
Since the 2SC1667 is still available, why substitute. The exact part can be ordered. Substitutes are fine if hte original is no longer available, but you should use the original when you can.
Dan
Jul 02, 2009 | Audio Players & Recorders
Dayton 1/2 hp dual voltage motor overheats (mtr #6k79). Replaced original motor with same motor overheats in 10 -30 minutes. White lead to #4 terminal, black lead to #1 terminal, ground to casing.
Wiring would be for low voltage 1-3, 4-2. L1 feeds 1-3 and L2 feeds
4-2. For high voltage L1 feeds 1 and L2 feeds 4 with the 2-3 terminals linked by wire or bus bar.
Jul 23, 2008 | Dayton Heating & Cooling
Reddy Heater-30-55,000 BTU Variable Logo
29 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
