Question about TalonSoft Video Game Consoles & Games
Cant play on current windows nt
I installed west front on my computer which is vista and it wont let me play a pop up comes up and says cannot play on this windows nt
  • 51 Answers
Right click on the game you want to play and click "properties". Click on the "compatability" tab and choose an earlier operating system. Try each till you find one best for your computer.
Posted on Feb 10, 2009
I am having trouble starting/playing Clive Barker's Jericho. I have installed the game fine and this took a short time of about 7 minutes. when i click on the word play in the pop up menu after i have...
the game was made for 2007 windows vista
you might be able to get it going by changing the compatibility mode -
http://windows.microsoft.com/en-US/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Oct 30, 2013 | Microsoft Age of Empires 2: Age of Kings...
I have windows vista trying to install a learning disk, But every time I try to install it tell's me that windows does not support NT what does that mean? and how can I fix it?
Have you ever installed this on a computer running Vista? If not it may not be compatible with Vista (this was my first thought when I read your issue). Check with the manufacture to see if they offer a Vista compatible version.
Jan 29, 2012 | Microsoft Windows Vista Ultimate Edition
My dell pops up with a blue screen and says "STOP: c000021a (Fatal System Error)"
To resolve this issue:
  1. Create a parallel installation of Windows NT.For additional information how to do so, click the article number below to view the article in the Microsoft Knowledge Base: 259003 How and Why to Perform a Parallel Installation of Windows NT 4.0
  2. Start your computer to the parallel installation of Windows NT, and then start Registry Editor.
  3. On the Window menu, click HKEY_LOCAL_MACHINE on Local Machine.
  4. On the Registry menu, click Load Hive.
  5. Type the path to the System hive of the prior installation, typically%systemroot%\system32\config\system, and then click Open.
  6. When you are prompted for the name of the key, type TEST, and then view the following registry entry: HKEY_LOCAL_MACHINE\TEST\Select
  7. Note the setting for the Current DWord value in the preceding registry key. This is typically0x1, and is represented as CURRENT:Reg_Dword:0x1. This value indicates that the "CurrentControlSet" for your original Windows NT installation corresponds to ControlSet001 in this window. A value of 2 would indicate that the "CurrentControlSet" for your original Windows NT installation would correspond to ControlSet002, and so on.
  8. Locate the following registry key HKEY_LOCAL_MACHINE\TEST\ControlSetXXX\Control\Session Managerwhere XXX is the CurrentControlSet that you identified in the preceding step.
  9. Under the Session Manager key, note and then delete any PendingFileRenameOperationsentries.
  10. Click the TEST hive, and then click Unload Hive on the Registry menu.
  11. On the Registry menu, click Load Hive.
  12. Type the path to the Software hive of the prior installation, typically%systemroot%\system32\config\Software, and then click Open.
  13. When you are prompted for the name of the key, type TEST2.
  14. Remove any PendingFileRenameOperations entries in the following registry keys: HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnce
    HKEY_LOCAL_MACHINE\TEST2\Microsoft\Windows\CurrentVersion\RunOnceEx
  15. Click the TEST2 hive, and then click Unload Hive on the Registry menu.
  16. Quit Registry Editor, and then restart your original installation.
Sep 30, 2010 | Dell Latitude D600 Notebook
When i turn on computer the dell logo comes uo and then it says its missin win32
Win 32 is the generic name for all 32 bit Windows platforms and includes Windowes 95, Windows 98, Windows Me, Windows NT, Windows 2000, Windows 2003 Server, Windows XP and Vista.
This is one of the Major program enable for your Windows to function.
So it would be best to perform a reinstall of OS
Sep 17, 2010 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Cant get west front to work with windows 2000?
I recently dug this game back out, it is really cool and wanted to play it again. It was still installed on my desktop Windows XP and worked fine but couldn't get it to run on laptop with exact same problem you described. After an hour of searching the net I found this patch which fixed it and now it runs fine. You can find it at the link below. Just select the appropriate one you need.
Good Luck,
http://www.theblitz.org/downloads/patches.php#cs
Jun 20, 2009 | TalonSoft West Front Battle Pack
Error Message on Talonsoft Western Front
NT is your operating system. XP is NT based.
You can reinstall Windows 98.
Here is the computer requirements:
System Requirements:Pentium 133 or higher windows 95/98
Or you can email the guy who made it at:
craig@redarrowproductions.com
Jan 28, 2009 | TalonSoft Western Front for Windows
Eltron p310 + Vista driver
i cant find drives forwindows vista....
Sep 29, 2008 | Zebra Eltron P310 Thermal Printer
Playing games
is the game compatible for the vista? check back of game box it will say system requirements, if it is there could be something for the vista you dont have in order to play the game or the game itself is a bad one,
Apr 23, 2008 | Video Game Consoles & Games
Video Game Consoles & Games Logo
480 people viewed this question
Top TalonSoft Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a TalonSoft Video Game Console and Game Expert? Answer questions, earn points and help others
