Question about JVC LT-26X506 26 in. LCD Television
Loud, high pitched hum from speakers . . .
Re: JVC LT-26X506 - A fairly loud, high-pitched hum from both speakers of the set even when it's muted and disconnected from the HD cable box. The tv is about 3.5 years old and did not make this noise until after our last relocation 3 months ago. Could the mover's (mis-)handling of the set have caused this, or is the problem due to a faulty/aged component?
    Sniper:
  • 105 Answers
This is GroundNoise from the TV's Backlight.
Sorry, but unless you are a Technician, you will simply need to ignore it.
If you are a technician, you can fix this by grounding the Audio ICs to the Power Supply (details not provided)
Posted on May 18, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
High pitch hum
The mechanism need work and so bringing it to a tape deck repair shop is the only answer if you want it to work again. Check the reputation of the place you take it to on the internet- a lot of places charge money but never fix the unit.
Apr 09, 2014 | Audio Players & Recorders
High pitch noises.
It sounds like feedback hum. Most likely caused by the settings on your computer. Try adjusting all the sound settings. Especially record settings.
Sep 01, 2017 | Numark ttUSB Turntable
I have a 42 inch Hitachi plasma tv that is making a very loud static noice coming from the internal speakers. It stays at a contstant very loud volume unless I completly mute the tv or turn the volum
Based on what you have tried if a buzz or loud static via the speakers you have something wrong in the audio output circuit of the set--problem here is that circuit may be part of the Main board that processes all signal---a look inside---following the speaker leads back would lead you to that board.
A simple thing to do to narrow it a little (you may have done this) is with sound all the way off put your ear to the internal speaker--hear anything at all like a deep hum?
Depending on age of set and cost of the board likely bad it may or may not be a do it yourself repair.
SD TECH
Apr 26, 2012 | Hitachi P42H401 42 in. Plasma HDTV
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
A high pitched loud hum (about a C) is coming from the freezer
That is your compressor. The bearings in them go bad and overheat. Sometimes it will even keep the compressor from restarting. You need a compressor.
Sep 05, 2009 | Frigidaire FRS23R4A Side by Side...
I have a set of wireless speakers which when
The hum is generated by incompatible Ohmage
one is 8 ohm the other 16 and it is overdriving.
If that does not appear to be the case then there is some lack of shielding on the plugs to the JVC.
But i would punt for the first option
Sep 05, 2009 | Televison & Video
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
They are makeing a constant sharp noise a loud high pitched hum if you will
Right-click on the speaker icon in the lower right of your screen and choose Open Volume Control and check all volume levels (make sure they are not set to high). If this doesnt work then when you right-click, choose Adjust Audio Properties and search around for volume controls (maybe try the Speaker Volume button).
Aug 04, 2009 | Audio Players & Recorders
JBL d110 /w no sound output
There is a standby indication that activates after 10-15 minutes without any input signal. I suspect that might be what the red light is telling you - no signal.
Loud hum from a loosened cable is normal as hum usually means there's an ungrounded connection somewhere acting as an antenna and the amp is doing its job to amplify what it thinks is a signal, in this case 60hz stray ac current is being sensed nearby. It's a good sign that you get hum from the sub because that means the amp is alive.
Avoid manipulating cable connections with the Sub or Receiver turned on as you could introduce a static spike that could harm any connected equipment.
Are you certain a bass signal is making it into the sub? The complexities of modern AV receivers vary in how you configure them to direct LFE to a sub. Bone up on that end of the chain.
Or, just hang a CD player on the Inputs of the sub and play something with a reassonable amount of Low Frequencies.
>>>> Be advised that this way of testing has NO VOLUME CONTROL because amps without volume controls always operate at maximum gain, relying on your external controls to attentuate it (hence, the loud hum from a loose cable); so choose a track that eases into the loud parts with some quiet parts up front and BE READY TO PAUSE THE PROGRAM AT ANY SIGNS OF STRESS. <<<<
A living sub will produce only muffled rumble in the absence of other speakers producing the higher frequencies which carry the intelligence of the signal. If that works, back to the receiver for settings. If not... sigh.
For hum problems, even those you cause yourself:
Disconnect all inputs to see if that helps. If it goes away start with the signal cables and add in things until it comes back.
Sometimes the reversing the orientation of the AC plug can help with hum. Or it could be something like a loose or high resistance connection internal to the sub. Good luck.
Jun 17, 2008 | JBL PSW-D110 Speaker
JVC LT-26X506 26 in. LCD Television Logo
347 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
