Question about Onkyo TX-DS575 Receiver
Only the Front Right Channel is working.
I've switched the speakers to check what the problem may be but it looks like the amp speaker channels are not working apart from the front right channel. What could be the issue? Fuses maybe? Please advice. Thank you, Harmeet.
  • Anonymous Mar 16, 2014
    when using mcaa the right front speaker channel has wea signal
It sounds like to me the transistors might be out in it they are on the heat sink inside check to see if there are any ones blown
Posted on Jul 29, 2007
Left speakers do not work
As power amps are just two amps joined together all you need do is identify the left channel and compare it with the right. Ignore any parts common to both channels. The first thing to do is a visual check. If something looks broken burnt, or odd compared with the right channel then you have probably found the culprit. I suspect you could have a power output failure. It might be that the output devices are separate transistors. They might need to be replaced.
By the way just follow either the internal speaker leads or the connections to locate the right and left channels.
Nov 10, 2017 | Yamaha HTR-6130 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
YAMAHA RXV350 RIGHT CHANNEL NOT WORKING
Adding on again: I have interchanged speakers, if i connect any speaker on the right front channel it will not work. When I do a automated speaker test only right front channel does work.
Jan 26, 2012 | Yamaha RXV-350 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
My Harman Kardon AVR 220 reciever's front-right channel isn't working. I have switched the two front speakers and the right speaker works on the left channel so it is not a problem with the speakers or...
if front left is working it is possible u have a dry solder on ur right channel line. try resoldering or if u want to know exactly where dry solder is, shake gently every right channel components and connections. if resoldering does not work it is possible u have a faulty ouput amp for ur right channel. if ur not sure about this i suggest u get it checked by a qualified tech.
Apr 05, 2010 | Harman Kardon AVR 220 5.1 Channels...
Front right speaker got wet, started cutting out. at the same time the rear right speaker started cutting. switched the rear speakers to opposite channels and this caused the right to work and left to cut....
the speaker getting wet will short it out. Shorting the output on any amp will ruin it. there is a right and left chanel with 2 outputs. Right chanel is damaged.
Sep 30, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Centre Channel speaker has stopped working
connect any speaker instead of center speaker if you get the same result you will have a problem in amp itself if the problem fixed change center speaker with a new one
Apr 11, 2009 | Audio Players & Recorders
Sound
Hi monmax,
I hope you are aware that in bridged mode your amp will become monaural (single channel, double power). If you still wish to bridge it:
Switch of power.
Set mode switch behind amp to "bridge" position.
Connect speaker positive to CH1+ve terminal of amp output and connect speaker negative to CH2 +ve terminal.
Be aware that now, in bridged mode your amps output power delivery is 1100 watts for a 4 ohm speaker and 900 watts for an 8 ohm speaker. Make sure your speaker can handle that.
Peace
Jango.
Mar 03, 2008 | Crown CE1000 2-Channel Amplifier
Subs
First of all you need to check if your amp can support this type of speaker setup? If you are simply going to wire 2 subs up to the amp (assuming a 2 channel amp) it's pretty simple. Just connect the + & - cables to one channel of the amp & the other ends of the cable to the sub, making sure that they are the correct polarity on both sides (ie speaker & on the amp).
If on the other hand you want to 'daisy chain' the subs onto one channel of the amp (this effectively drops the load down to half that of the speakers (usually 2 Ohm)), then you do as the name suggests. Simple connect one speaker cable to the amps channel 1 + ve output to subs_1 +ve input. Then from sub_1 -ve connector to subs_2 +ve. This leaves you with only 1 more to connect sub_2 -ve back to amp channel 1 -ve.
NOTE: make sure that your amp can support this first! If it can't then it's will auto switch off in most cases but can also damage the amp if there is no fail safe circuit built in.
Dec 24, 2007 | Rockford Fosgate FNQ1404 Car Speaker
Onkyo TX-DS575 Receiver Logo
147 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
