Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Will not turn on after a blackout
Last night there was a blackout at home, and the air conditioner (Vulcan Bonaire- Comfort Control) was running. When the power came on the AC was not longer working, and the screen on the control panel was completely blank. Maybe the system needs a master reset, but I have no idea how to do it. Please help, it is really hot!
    President:
  • 2,976 Answers
Check your breaker box. Also, check your receptacle. Some have a reset button at the receptacle. GFI Ground fault Interrupt receptacles are code for basements.
Posted on Jan 30, 2009
  • David Shaub Jan 31, 2009
    The fuse kachbibi1 mentioned would be located somewhere on the unit. It will probably have a small black cap on it marked fuse of jook like a raised black circular object with a slot in it for a screwdriver. It will take a buss type fuse.
  • 979 Answers
Turn off your breakers and then back on. There are fuses located in the a/c control panel. Check them. If you aren't getting any power still, a board may have been blown during the storm.
  • Johnathan Cache
    Johnathan Cache Sep 28, 2015
    Many people are having the same issue, for no reason at all, the thermostat is going blank, while still connected to power on the AC unit.
Bonaire Vulcan controller cct board 10 amp fuse keeps blowing
Obviously a direct short. Take pic, remove all wires, replace fuse. Wire by wire, turning power back on each time until fuse pops. When it does, there's your problem.
Jun 02, 2017 | Vulcan Heating & Cooling
Bonaire gas ducted heating not reaching set room temperature anymore...
has the system air filters been serviced lately
is the system circulation fab been cleaned to allow full air circulation of the system
call in a technician to check for vermin infestation preventing the system from working properly
Jun 20, 2016 | Heating & Cooling
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
Bonaire vulcan evaporative air conditioner
check your filter for dirts, clean or change it, check your evaporator and condenser coil and clean....
Jan 29, 2014 | Heating & Cooling
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
Servicing
Yes I would think so,a good r&r cleaning,once a year.
Nov 16, 2009 | Heating & Cooling
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Touch pad on
It is more than likely the touch pad that is faulty. I have installed many bonaires, and the only thing to go wrong at that age is the touch pad, or the problem is in the control box in the airconditioner.
The touch pad comes off quite easily by placing something flat behind the pannel and leavering it off gently. The touchpad has two pieces, the front, which you see, and the mounting bracket. The bracket is almost as big as the front pannel, so you only have approx 2-3mm of plastic edge to lever, so be careful not to hook onto the mounting bracket as well.
Once you have removed the front, you can then unplug the lead coming from the touch pad (be sure to turn the control box off in the airconditioner before removing this wire, there is a switch on the side of the control box (yes, you have to get on the roof, sorry)). Take the touch pad to your local retailer that sells Bonaire units and see if that is the problem.
Jan 11, 2008 | Heating & Cooling
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
1,832 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
