Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA D52W20B picture problem
My picture is showing blue, green, and red at the same time
  • 2 more comments
  • Anonymous Feb 01, 2009
    My 52" RCA has lost the convergence button from the menu and has colored lines also. I need help is this something anyone can fix
  • rrplett Feb 01, 2009
    my picture is doing the same thing showing all 3 colours
  • wettnosi Feb 02, 2009
    There are red blue and green lines that go through the top and bottom of my screen and it it bows in the middle so the lines pull towards each other! What can I do???
  • william o'grady Feb 06, 2009
    i had the coloerd lines running though my screen ,and after a couple of weeks doing that it just went black.now it doesn't turn on,the blue on light blinks on and off a few times and then nothing.my tv is only 3 1/2 yrs old.can someone please help. billyo.
  • RCA Master
  • 8,617 Answers
Most likely ifthe convergence option is missing from the on screen menu you will need to replace CL230, DL231, and FL231 you can get those parts with free instructions at the following link,
http://servicemanuals.vstore.ca/
Posted on Jan 31, 2009
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
How do you adjust color on a RCA D52W20B other than the remote?
Are you running component input on this--If so, make sure the red cable has not worked loose or gone bad.
Apr 28, 2014 | RCA Televison & Video
Clear but only blue/green color
Do you have a component cable hooked up to the TV? (cable with RCA connections Green/Blue/Red/White/Red)
If so you want to check that the red cable is tightly connected to both ends (TV and whatever it is connected to).
Good Luck...
Jan 23, 2010 | Toshiba 36A41 36" TV
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
