Question about HP J4680 Office Jet All-In-One Printer
Black line down my faxes
I have an HP Officejet v40ix. When I send a fax, it creates a black line down the left side of the paper.
    Genius:
  • 2,120 Answers
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
Posted on Jan 31, 2009
  • Leroy Elliott
    Leroy Elliott Jan 31, 2009
    Thanx for the Fixya!
How do I fax a sheet of paper?
First step is to connect the phone line to Line 1 Ext at the back of the printer port.
Place the document face down on the Scanner Bed Or place the document face up on the Top feeder if you want to use it.
Use the right arrow key and choose Fax Black and press OK
Dial the # you want to send Fax to and Press OK.
The fax should be sent.
Regards,
Ron
Dec 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Black line down paper
Pull the doc feeder open and clean the scanner glass
Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
When receiving a fax there is a black line down the middle of the paper
If you can copy or print and there is no line, the line is coming from the fax machine of the sender.
Dec 24, 2009 | HP Officejet 6500 Wireless All-in-One...
How to send fax from lexmark x4270. lost instructions
  1. Make sure your All-In-One is on.
  2. Load up to 30 sheets of your original document face down in the ADF. ascanld2.jpg
Note: When you load small paper sizes, place your original in the center of the tray and adjust the paper guides to the edges of the paper.
  1. On the control panel, press Fax.
  2. Use the keypad to:
  • Enter the fax number, and then press Black or Color.
  • Press Speed Dial, and then:
  • Use the arrow keys to scroll through the list to find the number you want, and then press Black or Color.
  • Use the keypad to enter a two-digit number (viewable in the upper left of the display), and then press Black or Color.
Aug 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Black line down middle of page
Clean off the glass place where the paper passes when you fax. You'll probably find some foreign matter on it. Wipe it off and you should be good to go.
May 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Black Line
You have to access the scanning glass strip. Some dirt is stuck there..
Jul 08, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
HP office jet J5740 all in one/Black line
are u trying to fax from the feeder or from the scaning bed .... try to follow this link CLICK HERE
Jun 06, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Faxes I send are reduced in size and have series of black line down right hand side.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Apr 27, 2007 | Canon LaserClass LC 8500 Plain Paper Fax
HP J4680 Office Jet All-In-One Printer Logo
154 people viewed this question
Seeker5211
Seeker5211
