Question about Kitchen Ranges
Our oven is not working. The broil works and the clean cycle works but the regular oven will not work. It's a Kenmore, about 5 years old. the stove works fine also.
  • 979 Answers
Check the wiring to the control switch. Located in the back of the oven. You may have a wire burned off the heating element. Turn off the breaker first, then pull the element out to see if the wire is burned off. This is probably the problem.
Posted on Jan 30, 2009
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
Auto clean problem
You say you checked the thermal fuse but did you check the broil element for continuity. Most ovens use the broil element for the clean function. The thermal fuse will shut off both the bake and the broil element.
Feb 16, 2014 | Whirlpool GBD307PR Electric Double Oven
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Cannot get oven unlocked after self cleaning
turn the circuit breaker off for several seconds
this should reset the system
Apr 02, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
