Question about HP J4680 Office Jet All-In-One Printer
I have an HP office jet v40xi (fax,printer,scanner,copier) and when I send a fax, a black line appears on the left side of the paper. How do I eliminate that line?
    Genius:
  • 2,120 Answers
Open the front door and clean the scanner glass attached to the bottom part of the door.
Posted on Jan 31, 2009
  • Leroy Elliott
    Leroy Elliott Jan 31, 2009
    Thanx for the Fixya!
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
When we send fax or copy it comes out black , can recieve faxes and print off fine .? hplaser jet 3050
Scanner's lamp damage
Try to open the lid on where we copy sheets of this paper hold down the sensor and press the copy button, see if the scanner lamp light, lamp power can be interrupted
Oct 27, 2009 | HP LaserJet 3050 All-In-One Printer
Thick line when goes throught auto feeder
The automatic feeder passes the page over the scanner, the scanner does move, so even a small mark (often find it is correction fluid) will effect the whole page, check the glass on the left side of the scanner for any sort of mark
Sep 08, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Every time I send a fax from my Dell 966, a black stripe appears down the middle. All photocopying/printing is operating normally, its just the fax that won't work! How do I fix this?
its quite possible the area that scans the paper(s) you are sending is dirty.
If the machine is one of those phone/fax/scanner/copier jobs, simply open the top panel, and with a damp cloth, wipe the runners that feed the paper through from left to right or right to left (just make sure any dirt you're wiping goes off to one side)
its also possible that a paper (that white-out was used on) that has been recently faxed, left some white out on the feeders
Aug 16, 2009 | Dell 966 All-In-One InkJet Printer
Black line down my faxes
Open up the document feeder and clean the scanner glass. Look straight down at the bottom inside of the door
Jan 30, 2009 | HP J4680 Office Jet All-In-One Printer
How do you make print size larger on hp office jet v40
When you bring up your directions in mapquest, under the red "MapQuest" logo in the upper lefthand corner there are these options:
prt-btn.png Print Save Send To Click on the "Print" option and a printer-friendly version will appear. You can choose "text and map" or "text only," then click on print and your printer options box will appear. I hope this helps.
Jan 04, 2009 | HP OfficeJet V40xi InkJet Printer
Scanning won't work
I had that problem. My OS is Vista. It's a Vista issue. To scan in Vista:
Load doc in scanner.
On comp click Windows Icon at bottom left.
Click All Programs, then Windows Photo Gallery, then File, then Import from Scanner or Camera, then HP Office jet XXX / then Scan
Nov 02, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
HP office jet J5740 all in one/Black line
are u trying to fax from the feeder or from the scaning bed .... try to follow this link CLICK HERE
Jun 06, 2008 | HP Officejet J5780 All-In-One InkJet...
HP J4680 Office Jet All-In-One Printer Logo
106 people viewed this question
Ben Johnson
