Question about Pool & Spa
I need a replacement gasket for my Primier pump model# 556N-20R which is 2 HP. This has a 5" diameter
  • 547 Answers
You can get ahold of a pump company and have it shiped to you
Posted on Feb 11, 2009
I have oil around the sparkplugs
Valve cover gasket set
Replace it/them
Nov 02, 2014 | Toyota Camry Cars & Trucks
I need to know if I can put a bigger pump on my 2000 BS I found a 2400 an also if the diameters would be the same
You can technically put a bigger pump with your existing unit. I'm not a 100% sure what your HP rating on your B&S is. Do the research on the 2400 pump first and make sure that a larger engine was needed in that application and if so, the input diameter of the pump may be slightly bigger to accommodate a bigger engine. Generally engines ranging from 5 through 7 or maybe 8 HP will have the same diameter shaft. Hope this information helps.
Mar 09, 2014 | Briggs & Stratton Garden
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
I am trying to find a replacement for ann XP2
the 2" is inside diameter so you more than likely have a 2" suction/discharge. The motor is probably rated 5hp, especially since it is both a circulation and jet pump.
Dec 01, 2009 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Location and placement of a water pump
ok you will see a pulley with NO GROVES with FOUR 10mm bolts
that's the water pump
remove that pulley
then there are FIVE 8mm bolts holding the water pump to front cover
remove the 5 water pump bolts
then use a screwdriver and hammer and tap the pump to seperate the pump from the cover
clean the old gasket off and reassemble
hope this helps
Dec 01, 2009 | 1997 Chevrolet Venture
I have a Speedaire model 3z492 air compressor. The manual is gone and the information plates as well. I need to know if this model is cappable of maintaining 100 psi @ 10cfm? Any ideas?
Here is info I found "Pump:
Two Stage, Cast Iron, Compressor Pump, 5 HP, 17.1 CFM Maximum Free Air Flow At 175 PSI Maximum, 2 Cylinder, Oil Capacity 2 Quarts, Pump Speed 685 RPM, Bore Size 4 3/4 x 2 1/2 Inches, Stroke 3 Inches, Motor Sheave Diameter 6.75 Inches, Flywheel Diameter 16 1/2 Inches, W 18, Depth 16 1/2 Inches, Height 22 1/4 Inches, Outlet 3/4 Inch NPT, Mounting Holes 8 3/4 x 5 3/4 Inches"
Nov 08, 2009 | Air Tools & Compressors
Tsurmi LB-480 2" male adapter to the hose
You can either replace it with another 2"male hose adapter or just replace it with 2"diameter GI pipe nipple x 4"length and hose clamp for 2" diameter.pipe. Just send your e-mail should you need further assistance.
Jul 07, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Replace water pump
REMOVAL: 1) Remove the plastic belt routing diagram (there is a bolt underneath if I remember correctly)(yep, 8mm). 2) Using a 3/8 breaker bar or a ratchet, insert into the belt tensioner and push toward the back of the engine enough to release tension on the belt with one hand, and with the other hand, remove the belt from the water pump pulley. Then remove the bar/ratchet from the tensioner. 3) Remove the 4 bolts holding the shiny pulley onto the water pump (11mm). 3a) Large catchpan underneath, there's more coolant in there than it looks like. 4) With a ratchet and possibly a short extension, carefully remove the 5 bolts that hold the water pump onto the block (8mm). 5) Pry the water pump away from the block and clean both surfaces so they are free of gasket material. INSTALL: 1) Line up the gasket and *carefully* fit the new water pump onto the block. The holes are very easy to line up wrong because they are almost, but not quite, equally spaced from each other, so be VERY careful you have all 5 holes lined up right. 2) Screw each bolt in a few tuns to make sure they all go in smoothly. If you get any resistance (it will feel like it's crossthreaded), you have the holes wrong, and you need to rotate the water pump so the holes are lined up right. I can't stress this enough. 3) Torque all the bolts down (I can't recall the exact in/lbs - sorry) in a star pattern. 4) Mount the pulley onto the water pump shaft, torque bolts down (an air ratchet helps greatly here as the shaft will try to spin when the bolts start getting tight). 5) Release the tension as explained in step 2 at the top, put the belt back on the water pump pulley & double check to make sure it's on all the other pulleys while you're at it. 6) Bolt the plastic bolt routing diagram back onto the head. 7) Refill the resevoir and bleed the system of air. That's it! It's an hour or so job if you've never done it before. Note, if you're not using a gasket, get some water pump gasket sealer and make a gasket around the entire diameter of the mounting surface of the water pump. Remember to make little circles around the bolt holes also.
May 15, 2008 | 1999 Pontiac Montana
Pool & Spa Logo
467 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
