Question about LG WD-14124RD Front Load Washer / Dryer
Washing machhine takes water and then switches of
Washing machine takes water and then goes of and switches the electricity of aswell, why does it do this can you help please
I have a front loading whirlpool that did the same thing, I removed the bottom cover,then where the drain hoses go is a filter trap. You unscrew the cover, pull out the trap, clean out the loose change and junk,then screw the trap back on and your good to go.Make sure you try to get as much water out as you can, because what ever is left in the washer will come out as soon as the trap cover is removed.
Posted on Jan 30, 2009
  • 640 Answers
Check for a weak circuit breaker...we need 15 amps alone...onthejob
Washing machine keeps tripping the electrics
you have bad circuit breakers in your house power center; replace them with the correct amperage value for your machines or, call an electrician
Feb 04, 2013 | Washing Machines
My washing machhine doesn't wash or rinse it only works on spin
If not filling with water check water is on and fill solonoid valves .
Jun 19, 2010 | Washing Machines
Water didnt pump out properly now its not coming out at all whats wrong
possible blocked pipe,while machine is full of water take the outlet pipe and lay this as low as possible into a bowl. if no water comes out then you have a blocked pipe. 1st if there is a filter remove drain plug and check filter. If no filter then you need to remove rear panel, Under the sump there is a large black hose, this goes to the pump. By removing the sump side of this hose with suitable tool you can check inside pipe. You may also need to check waste pipe aswell.
Feb 18, 2010 | Washing Machines
Hi, I got a Fridgiaire front load washer. I got an error code E 41. Machhine won't start at all. Replaced the board. Now water enters machine for 15 seconds then stops will not spin
The E41 error means the control thinks the door is open. From your description of the problem the most likely problem here is a bad door switch assembly.
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
If I can't get the water t6o come out when the
Try this, use the manual fill in the top of the machine, remove the sprayhead, put an airpot under machine and pour water into the machine at least 3 liters, until it pours out of brew tube. If that works, then the problem lies in the solenoid or the ling bringing water to the machine.
Jun 18, 2009 | Bunn CWTF15-TC
Will drain not fill up and eco button flashes
check if any of the valves are getting voltage,if they are and still not filling,turn off machine and unplug-coil far valve should be around 3.4kohms,they go open circuit sometime,check the small pressure switch pipe for blockage aswell hope this helps----follow safety guidelines always when working on electrical equipment
Apr 28, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Boiling water in Miele automatic W750
Hi,after posting I had the enlightened idea to run the machine again.Gut told me it was a blip,rather than a defect.Has run 2 cycles with no problems recurring.We keep our fingers crosswise!regards henk
Jan 08, 2009 | Miele Novotronic W1918A Front Load Washer
Washer will not stop taking on water although off.
If the machine is takin on water when it is off aswell as on then its the solenoid at the back these are what the hot and cold water pipe are connected to. its will one of them not both.
IF its only takin water in on the wash then its the presurre switch.. most commonly what happends is that a small tube comes up from the bottom of the drum and goes up along the side of the drum and is attached to an electrical pressure switch. when a machine is filling it traps air in that tube and the pressure increases upon that air which force the switch to open and cut of the water
so its either the solenoid or faulty pressure switch or the little pipe is either disconnected or damaged.
hope that helps
Dec 10, 2007 | Washing Machines
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
LG WD-14124RD Front Load Washer / Dryer Logo
62 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
