Question about Motorola MU21CV (1 Channel) 2-Way Radio
Taking apart a mv21cv radio
Hello I would lke to know how to dissemble my MV@!CV motoroal radios
  • w1pat Feb 06, 2009
    i need to access the power input and cant figure out how to take the radio apart
Just did this on mine. Remove the battery cover and battery. With a small flathead screw driver pry the left and right side of the battery tray away from the wall. then pry up the bottom of the tray, flip it up and remove it. this will expose two black plastic tabs near the top of the battery compartment, one on each side, pry them gently away from the wall to release the catches and then insert a screwdriver between the circuit board and the bottom of the case, this will push the whole assembly out the top of the radio as one piece. Be careful you are bending alot of fragile plastic.
Posted on Feb 18, 2009
How to dissemble the factory radio?
Depends on the make and model, some you have to remove the face of the radio and use special clips to pull the radio out, you maybe able to find those pieces at radio shack
May 29, 2014 | Cars & Trucks
Need AC adapter Motorola Talkabout T5720
Hi Tom,
Take your radio to your nearest Radioshack or similar store and I'm sure the team there will be able to help you with an adapter (charger?)
Oct 07, 2012 | Motorola Talkabout T5720 (7 Channels)...
Car radio code for ford ka
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Aug 21, 2012 | Car Audio & Video
I have a motorola mv11c and it works fine and I just purchased a pair of motorola mv21cv. They must be on a different frequency my question is how do I change the frequence on my mv21cv radios to be...
Hold in the PTT button while you turn on the radio. It will announce the frequency number. You can use the PTT button to change the number. Then press the Monitor (small possibly red) button to lock in your setting. The next number your radio announces will be the Code. Use the same method to change the code if needed. Then press the Monitor button to lock in your setting. Once you have set both your freq and code you can turn the radio off, then turn back on normally and use the radios.
Best regards.
Jul 22, 2011 | Motorola MU21CV (1 Channel) 2-Way Radio
Intermittent no transmit not all the the time hw do fix ?
It sounds like you have a cold solder Joint on the Board of your radio. You will need a power supply, a watt meter, dummy load and a 30 to 40 watt soldering gun, solder and solder wick. Chem wick makes the best solder wick. DON'T buy the solder wick from Radio Shack.
Take a non Metalic item lke the handle of a screwdriver and tap around on the bottom side of the PC board litely untill you find the general area that is causing the problem. Start solder different points on the board until you find the joint that is causing the problem. If you accedentally put too much solder use the solder wick to remove the extra solder. This is time consumming and you must be careful as too not short out the radio. Also the solder gun must be isolated from ground.
This is not a job to be taken litely. I would reccommend taking the radio to an experianced Radio Technician unless you feel that you can handle the job.
Jul 16, 2011 | Magnum Radio Communications
My radio will not play or charge a batterie while plugged in. I put in a new fuse because the original one blew and as soon as i plugged it back in it blew the new one. It will run with a charged batterie....
my name is Falco, are you ready to take the unit apart ? do you have the necessary screwdriver ? do you have a volt meter ohm meter ? and do you know anything about electronics ?
May 05, 2011 | Dewalt DC011 AM/FM Radio
I need to download the owners manual for the motorola mr355r 2-way radio.
iam collins ,iam using motoroal v360 for 3 good years.bat is now restarting and freedownload v360 software09c56d4.jpg
Oct 29, 2010 | Motorola MR355R Two Way Radio
Users manual Radius P1225
all u need 2 do is google free manual motorola ht1000 or i would see if u can go 2
Jul 08, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
How do you take the radio out?
Ford used a specific meathod for factory radio removal but I can't be positive they used it in 93. There should be four holes in the radio, 2 on each side about an inch vertically apart. If that is what you have you need to buy Ford OEM radio removal tools. I saw them at Pepboys a while ago and recently at Best Buy. They are about $10. You put these tools in the radio and gently press outwards and the radio should come out.
Mar 25, 2009 | Car Audio & Video
would a MU21CV be a VHF or UHF????
Aug 12, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Motorola MU21CV (1 Channel) 2-Way Radio Logo
239 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
