Question about Panasonic MC-V7398 Upright Vacuum
My vacumm keeps burning up belts i need to make sure the proper way to install new belt
    Sergeant:
    Champion:
  • 373 Answers
Does it need a real good cleaning
and make sure nothing in stuck in it
Posted on Jan 31, 2009
Hoover Windtunnel Bagged upright vacuum is smoking and belt is slitting and burning
you probably need to replace your brushroll seeing that your belt is burning means motor is turning. first check you brushroll and see if there is an obstruction keeping it from spinning if its not spinning freely replace
Jan 16, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Why do the belts keep breaking
Well the problem happens due to the belt If the belt not installed correctly, the rubber belt will grate against one of the components in the roller brush housing. The friction of the belt against the housing produces a pungent burning odor. To correct this you need a right belt, each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn.
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Bissell 3576 CleanView II Bagless Upright...
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
Belt burned up (first time); installed new belt but that starts to burn also; approx. 2 years old
Sounds like the brush that the belt is supposed to turn is bound up tight. Need to remove the brush and clean all debris from it. Where you can get at the center rod for the brush, the rod that the brush spins around, clean the ends and add some WD40, being sure not to get it on the belt. This should remedy the problem of the belts burning as long as the belt is put on correctly.
Aug 27, 2010 | Panasonic Vacuums
I replaced the belt with part# 40201 on my Hoover model# U5473-900; to only have it break again in 5 seconds! Is there something missing that holds it on that little bar?
Greetings,
When a brand new belt breaks in 5 seconds, this can only mean 1 of 2 things.
1. The roller brush itself may be bad and need replacing. If the roller brush's bearings lock up, and the brush can no longer spin freely, this will cause the belt to burn up immediately after you turn the vacuum on. You may test your roller brush by taking it out of the vacuum, and hold it on the very ends of the brush with your fingertips. Make sure you are only holding the bearing caps and not the brush itself. While holding the two bearing caps with your pointer fingers, try to spin the brush with your thumbs. Does the brush spin freely? If no, then you'll need to buy a new roller bush for your vacuum, unfortunately the bearings are not sold separately on Hoover vacuums. If the brush did spin freely (you should get at least 7 rotations out of one spin) then see reason number 2 below.
Your model uses Hoover Agitator Brush Part 48414132.
2. The belt was installed incorrectly. When a belt breaks immediately like this it can also be a result of it not being installed properly. When installing the next belt, after you have put the roller brush back into place, pull forward on the belt to make sure that the brush spins when you're pulling forward. Sometimes I pinch the belt underneath of the brush roller, and it will not spin freely, and will burn immediately if the belt is pinched.
It really can only be one of these two problems. I hope that this repair solution was helpful to you. If you need me to clarify something, please just request clarification here. If it did help, please be sure to rate my repair Helpful. Thank you so much!
Chris J.
Mar 13, 2010 | Hoover Vacuums
I have a Eureka Altima vacuum. The model number is 2996. I don't think my vacumm is sucking any dust. Plus, it smells like a burning leather. What should I do? I have tried to get help from others and they...
Sounds like the belt for sure. Here is a link with the owners manual. It shows how to get to and change the belt.
http://www.eureka.com/index.php?option=com_productdisplay&view=productdisplay&task=getproducts&productid=2&product_model=2991AVZ
Sep 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Belt slips off motorshaft
It could be an old belt even if the upright is new. Check that the beater bar is not clogged with dust or threads and find a replacement belt for this vacuum and fit it to see if there is any difference. If not, then there's a problem with the vac and it should be returned.
Apr 02, 2009 | Dirt Devil Featherlite Deluxe Bagged...
I am not sure how o install a new belt on my oreck vacumm, can't
here is the insturctions (copy and paste in your address bar)
http://www.oreck.com/vacuum-cleaner-bags-and-belts/index.cfm?keycode=DB475
Feb 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacumm Belt keeps coming off.
stick a little bit of tape on the inner half of the spindle, this will put an angle on the belt and should prevent it slipping off.
Dec 23, 2008 | Hoover Vacuums
Kirby heritage II
As long as it is Kirby belt - you should be fine. Make sure that the shaft is clean and that you do not vacuum something greasy or wet (grease or oil will lubricate the belt and shaft will loose the grip -heat up and burn). Make sure that brush roll spins freely.
I am assuming you know how to put the nozzle on properly (if you not sure - go here)
Good Luck
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Panasonic MC-V7398 Upright Vacuum Logo
160 people viewed this question
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
