Question about Frigidaire FRS26R4A Side by Side Refrigerator
Door ice dispensor will only dispense crushed ice
Gallery refrigerator - with the button selected to dispense cubed ice on the door it will only dispense crushed ice
Pull out the ice drawer and close the door switch the crushed /cubed button put the ice drawer back in and switch the selector button again. You might have to repeat the process I had the problem this week and by jiggling everything around and running a good bit of ice thru it started working again. Good luck
Posted on Mar 17, 2009
I only get crushed ice even when the button is on
Pull the ice bin out and you'll see a rectangular hole with a plastic piece that has a rectangular hole in it. This piece will correspond to a steel rod that runs along the bottom of the ice bin. This steel rod actuates the crush/cube option in the dispenser. Sometimes icing can cause the plastic piece to get stuck. Try "jiggling" the plastic piece up and down until it frees and operates easily. Then replace your ice bin and try operating the controls on the dispenser again.
Dec 11, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
http://www.apdepot.com/Buy/IPLFrame.asp?Brand=GE&ModelNo=GSH25KGMDWW&IMGFile=LD1IEWSN&IMGID=uZmA
Aug 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by side only dispenses crushed ice
Below is the link to parts the manual for the model listed now we need to determine if the switch in the door is bad or wiring fault.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
This link below is a Q&A's and also very helpful for parts and answers
http://www.applianceaid.com/refrigerator.html#freezing
Let me know what you would like me to do. Fact is everything you need is on the pdf if your part# and MFG. Is correct. Let me Know, Thanks, Sea Breeze
Jan 30, 2009 | Frigidaire FRS26R4A Side by Side...
Ice dispensor only dispensing crushed ice - not cubed
Make sure that your ice tray is properly instaled. There is a rod that must go into a hole. When you select ice cubes rather than crushed ice a solenoid raises which moves that rod. It then opens a flap so the cubes can bypass the crusher. Either your rod is not in the hole correctly or the solenoid has gone bad. The rod that I am speaking of runs along the underside of the ice tray. It has a spring on the rear end that holds the bypass flpa closed.
Dec 02, 2008 | GE GSH22JFT Side by Side Refrigerator
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
247 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
