Question about HP Compaq nc6220 Notebook
Audio Input Problems
The specs of this notebook claims to have a "stereo" mic input. I cannot record any form of external stereo sound using the 3.5mm stereo mic socket on the unit. I have selected the "Line" as my input source within my volume control settings, as well as ensuring that the "line" output is NOT muted. I want to record stereo audio from another device (ipod/cd walkman)but the line input doesnt seem to work. If I select "mic" as the recording source all I get is a mono sound recorded (proving that a signal to the notebook is present). Any assistance would be appreciated.
  • Arthur Eschner Jul 30, 2007
    Hi again, ok I tried looking for an aux input to select but none available. I have CD Player, Mic, Line In & Wave out. I now have made some progress, I can record in stereo if I select Microphone. The problem with this is that the sensitivity/gain is so high that if the volume is set down to a bare minimum on my device & the slider on the windows vol/rec control almost right down, I am only just able to record without distortion (very little room for error there). I am also not able to hear (monitor) what is being recorded - no matter what software I use.
    Brigadier General:
  • 6,966 Answers
Hi, try using AUX instead of Line. If AUX is not displayed in the Volume Control Setting Window (Speaker), click on Options/Properties and click on AUX box to put a check in it. I would appreciate if you would post again on how things turn up before you rate this solution so we can further discuss your problem. Good luck and Kind regards.
Posted on Jul 30, 2007
    New Friend:
  • 83 Answers
Buy a creative sound pcmcia card with stereo inputs...it runs aboout 50 bux at compusa...another solution would be usb audio input, they are also available at compusa,tigefr direct...i hope this helps...
6ya staff
SOURCE:
Is mic jack in lenovo SL410 stereo?
From what I could see from the Specs of Lenovo SL410, it only takes a 3.5 mm Microphone Plug. You could always use a 3.5 mm Stereo Audio Mic Jack and use Software like Audacity for Stereo Audio Recordings.
Jan 10, 2015 | Lenovo ThinkPad Computers & Internet
How do I find out what specs my sound card has? have a Dell lattitude 6400 and am considering buying software which requires Creative Labs Sound Blaster 16 or equivalent sound card supporting 16-bit...
Your laptop has a High Definition integrated sound card which will do just fine for low-to mid end recording. You'll just need to hook up your audio source to the Microphone input on your laptop using a standard DIN plug, just like the one used for headphones. Usually the plug is a stereo input so you can have full stereo recording using the Microphone input.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Feb 01, 2011 | Dell Latitude D600 Notebook
Can I record stereo via the mic input on my Dell Inspiron 2200 please? Is there any way of getting a high quality stereo recording from a line level input signal without investing in an external sound...
Try using Musicmatch Jukebox,it`s a great program for this and doesnt cost much..has to be pro version to record.You can choose both line and mic stereo recording as well as burn audio cd`s...lots of great features...good luck:)
Apr 12, 2010 | Dell Inspiron 2200 Notebook
Ipod input for sa-eh760
You can plug the Ipod into the mic input , to do test recording. But the result wont be great.
To listen the Ipod in your stereo you should plug the Ipod into the Auxiliary input on the stereo.
Naturally you do not need any dvd.
Here is the adapter: 1.5M 3.5mm Male to Male AV Audio RCA Y Adapter
Feb 17, 2009 | Technics SCEH790 CD Shelf System
How to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
Jan 05, 2009 | Acer Aspire 4315 Notebook
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Sound is coming out like broken speakers when using stereo input
The sound card would almost certainly fix the problem. One thing to do is to try a program like Audacity which will help you determine where the problem is. Then try it with your mic setup as it is.
Nov 01, 2008 | HP Pavilion dv9000z Notebook
Direct sound is not supported....
Follow these steps (Windows Vista):
Control Panel - Hardware and Sound - Sound - Manage Audio Devices - Record - Right click to show all the devices (including the deactivated ones) - Activate all the devices you can.
In Adobe Audition:
Edit - Audio Hardware Setup - Edit View - Control Panel button - Direct Sound Input Ports - Enable one device (default input will now show the device). Now you will be able to record sound.
Jul 24, 2008 | Adobe Audition 3 for PC (22011292)
External mic
No you can't !! This unit only has an audio out but the mic is built into it. You have to speak into the WBT210 when you connect to a phone call.
Mar 14, 2008 | Jensen WBT210 Consumer Microphone
Tascam us 144
Stereo requires two different inputs, as the very name implies. If you're using just one mic, it is possible to "pan" that input to both left and right, but is not truly stereo. For true stereo, you must have at least 2 mics, or 2 or more of any other sources...accordianman
Feb 22, 2008 | Tascam US-144 Sound Card
HP Compaq nc6220 Notebook Logo
222 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
