Question about Hunter 52" Ceiling Fan With Light And Remote Control
Replacing old fan with Hunter 20763.
Old fan wiring was white from fan to blue from ceiling and Red and Black from fan to white from ceiling.
New fan wiring instructions call for white from fan to white from ceiling and black and black/white wire from fan to black from ceiling.
Can you help.
Thx
Dan
  • 37 Answers
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
Posted on Jan 31, 2009
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
Hunter Old Thyme 22272 Ceiling Fan Internal Wiring
White to white (Nutural) Red to hot wire (usually black) &If you have two hot wires the blue(light wire) would go to the other hot wire. If you only have one hot wire you put the black & blue wire together and connect to the hot wire.You will have to use the pull chains for both if you only have one hot as the fan is an old two speed and they do not make a fan control for the wall for that fan anymore. Also ,you will have to oil the fan after you hang it.Only use the Hunter oil.
Jan 26, 2013 | Hunter Dryers
I have 2 wall controls for my current fan. One is for the light on the fan and the other is for the fan itself. When I disconnected the old fan, there were 3 wires - black, white and red. What do I...
Both the Red and Black wire are your hot wires. One is probably for the fan side and the other the lights. The white is your neutral wire or common and is used by both. So the wires from each switch are HOT, hook one wire to the black and the other switch wire to the red.
Jun 05, 2011 | Hunter 52" Ceiling Fan With Light And...
Im installing a remote to Hunter fan w/light. A White n Black coming from fan, Remote has Red,Black,White n Black n White to go to ceiling.Where do the red,black n white from remote go to on the fan? Thank...
Black goes to the black on the fan white goes to the white on the fan and the red will go to the blue wire on the fan for lights. Now if you have a black wire with a white stripe on it from the fan that is the light wire.
Apr 20, 2011 | Hunter (25417) Ceiling Fan
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Hunter ceiling fan
The usual house wiring for a ceiling fan with two wall switches , is white to white, black to black, and red to the other wire, usually blue or black striped with blue. If this fan has a remote , then it usually only requires one power wire, black and the white neutral.
May 03, 2010 | Hunter 27187 Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Wiring connection ceiling fan
copper to green , white to white , seperate the black and the black with th white tracer you wired together connect the black to the black and the black with white tracer to the red in ceiling , without looking this is my best advise ,good lk
Mar 24, 2008 | Hunter 20531 Vista Brushed Nickel Ceiling...
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Dec 26, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Dryers Logo
233 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
