Question about HP OfficeJet 7130 All-In-One Printer
Print head clogged
I put in a new cartridge and the red still doesn't show up. Do you think a print head is clogged? If it is how do I clean it? I have done the printhead cleaning on the machine but to no avail.
  • 2 more comments
  • mabzie54 Jan 30, 2009
    I got it working! Thanks.
  • Thomas F. Schneider May 11, 2010
    Try Taking it out and soak the bottom in rubbing alcohol untill the ink has softened, then reinstall it and do a print head cleaning. .
    Take cartridge out and Try rubbing alcohol on a cotton swab over and over until the ink has softened, where it comes out from.
  • Steve Gilbertson
    Steve Gilbertson May 11, 2010
    I can't seem to see what kind of printer you have do you have a color cartridge and did you replace it?
    President:
  • 2,692 Answers
FixYa?
Posted on Jan 30, 2009
Photos are printing with too much blue un them. I have changed the color cartridge, cleaned print heads, etc. I am using only Epson namebrand products. Is there any adjustments I can make to correct this?...
It sounds like the print head may be clogged. To clean print head:
  1. Get a saucer and fill it with hot water
  2. Dip the print head in for 30 minutes
  3. Wipe the print head with a dry cloth
  4. Repeat the above at least 3-4 times (replace the hot water in the saucer each time)
  5. After repeating and wiping down the print head, put it back in your printer, put the cartridges in and run the print head cleaning function 2-3 times.
If it still doesn't work, then you may have to replace the print head.
May 10, 2011 | Epson Stylus Photo R280 Series
All the pages I print are blank. There is sufficient ink the print preview shows the image but the actual print out is blank
Sounds like your print heads are clogged. This is quite common. Go into your printer's menu and find the maintenance menu and follow the steps to clean your print heads. Run the process everal times until the prints are 100%. Then run a printhead alignment. Regardless of whether your not your ink is full, if cleaning the heads several times does not solve the issue, put new ink cartridges in because you may have bad cartridges. If that doesn't work, you've got bigger issues, contact the manufacturer.
Apr 26, 2011 | Office Equipment & Supplies
Printer has new ink cartridges, no apparent mechanical or sensor obstructions or failures, yet still fails print alignment. I've reset all the factory defaults, performed head cleaning, etc. I can find...
The print heads are probably clogged :^(
Has the printer been unused for some time? Does the printer show that the cartridges are full?
Does the printer show any errors? It could be that he waste reservoir is full (or thinks it is full) I would suspect that it would report an error though.
If the printer was not used for a while, the ink could be dried on the print heads. Print heads are kind a like paint spray cans. You can try cleaning the print head nozzles with alcohol and or water. The best way to do this is to put a moist (you do not want liquid to drip into the system though) cloth or paper towel under the nozzles. Make sure the printer is unplugged though so any liquid does not fry the electronics. Make sure the printer is completely dry before plugging in again.
Hope this helps, Jim
Feb 10, 2011 | HP Photosmart Premium C309A All-In-One...
My RX690 will not print red, what is supposed to be red comes out yellow. I have swapped in new cartridges and they are all in the correct locations.
Most likely the Print Head is clogged for that color. You can either do a head cleaning. If that doesn't work.
Take the cartridges out and put a few drops of isopropyl alcohol in the bottom of each head where the ink goes thru. Let that sit for a few hours, then reinstall the cartridges and run the head cleaning cycle a few more times.
Jan 08, 2011 | Epson Stylus RX690 InkJet Printer
Print outs are blank, cartridges are fairly new, indicator shows there is ink almost a full cartridge! why doesn't any think print out?
The ink-jets that s[t]uck ink from the cartridges and spray the ink onto the paper are CLOGGED.
Use the printer-software on your computer to run a few "print-head-cleaning" cycles.
Jan 05, 2011 | Office Equipment & Supplies
I haven't used my canon pixma for a few weeks, came to use it again and the 3e black cartridge won't work, (tried printing from computer and copying) have done a clean, deep clean and nozzle check, even...
The black print head is clogged. The reason why the black is clogged and not the photo black or any colors is that the black is pigment ink and the photo black and colors are dye based ink. The pigment ink is a particulate formulation that binds up when water is evaporated out of the ink. You need to buy a new print head the fix the problem. You can buy a new print head for $75 from precision roller.com.
Mar 18, 2010 | Canon PIXMA MP780 All-In-One InkJet...
My printer just prints in very light red
You are out of red ink, OR the print head is clogged (but that usually) produces streaky lines more so than light color.
You can try cleaning the print heads:
  1. Open the 3845 desktop assistant c00026601.gif icon on your desktop or start menu
  2. click on utilities or tools
  3. click maintenance
  4. click clean cartidges
  5. follow the on screen instructions
If that doesn't help, you're either out of ink in which case:
  1. Buy a new cartridge (or have yours refilled professionally)
or your print head is clogged beyond repair, in which case:
Happy printing.
Jan 27, 2010 | HP Deskjet 3845 InkJet Printer
My brother mfc 420cn printer quit printing...
I'd venture to say that if you haven't used it in a while the ink dried up and clogged the print head. It is probably a job for a service center. Good luck
Aug 05, 2009 | Brother MFC 420CN All-In-One InkJet...
Put in new cartridge for the epson stylus c88+ and they do not print out the ink first black and now yellow. It was working now nothing !!! Help
hi...
Just try to head clean, then print a nozzle pattern if na print out are still the same, i think your head have problem... it called clog.... just use syringe and cleaning solution and pump the panel of head so that the clogging remove in your printer head....
May 08, 2009 | Epson Stylus C88 InkJet Photo Printer
Unable to clean Epson C88 Nozzle
In view of leke0513's lack of interest in this problem, I think we may say it has been "solved by poster".
Mar 25, 2009 | Epson Stylus C88 InkJet Photo Printer
83 people viewed this question
Ben Johnson
