Question about Acer Extensa 4620 Notebook
Want to install 4Gb
Hi,I've been told the reason my 2 x 2Gb RAM won't work is that the BIOS needs updating. I have downloaded BIOS v1.33 but cannot see how to install it. It unzips but doesn't install. I've tried through DOS but phlash16 comes up with BAW-133 file error.Any help appreciated
  • 50 Answers
Memory is a tricky thing you have to make sure that the meory is compatable with your mobo(for instance) my laptop is a acer aspire 3000 it takes pc2700 ddr memory that runs at 333 mhrtz i just upgraded from a 128 and 512 set to 2 gig im running xp home,also xp will only recognizes 2 gig max unless it the 64 bit ver which then will go up to 4 gig and up also vista as well will run up to 4 gig and up usually 64bit ver will recognize 4 or more gig however if you need soem more help id need make model of laptop your running as swell as which ver of windows.happy hunting-z
Posted on Feb 20, 2009
Need install more ram
Hi.
you have to use DDR 2 RAM with 800 mhz .
you`re Manuel say`s maximum is 4GB.
maybe a BIOS-Update can help to use more than this 4 GB.
otherwise you need a new Motherboard to fix this.
lg Gue.
Dec 29, 2013 | Shuttle XPC PC Desktop
Dnt have enough ram to install internet. how do i update my bios so new ram will work on emachines 400i3.
I did a little research on this model, and sadly it may be time to put it to pasture. It uses Win 98 with a 4GB drive. This tells me it just can't handle today's media rich internet. Let alone finding a BIOS upgrade.
GL
Jan 09, 2013 | FSP Emachine eTower 400i3 Power Supply...
I upgrade RAM on laptop, now runs slower. Running 64-bit WIN 7 OS,
Check BIOS if all RAM is being picked and or set to max on RAM settings.
Upgrading BIOS! If it isn't broken don't fix it. Upgrading is a scapegoat fix, and many manufactures have a disclaimer. "You are on you own, and the likes for a reason. Most solutions are found elsewhere.
However, if you truly need to update read this to help you with the upgrade.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
GL
PS. Many applications are written for 32 bit, hence they are unable to fully utilize 64 bit and may be bound to 4GB.
Oct 09, 2012 | Gateway NV7802U Notebook
I m trying to upgrade my HP compaq nc6320 RAM MEMORY from 1GB to 4GB, Do i need BIOS upgrade if yes from were i can find the drivers and how can i do it? thanx i am gone wait for respond......
As far as I know, the machine supports 4GB of ram, so you purchase the ram modules from a pc parts dealer and install them inside the machine, removing the existing ram, there are 2 slots, so you need 2, 2GB cards.
You do not require any drivers or bios update.
Windows will need to be upgraded to 64Bit version if you wish to use the full capacity. as normal windows is limited to 3-3.75GB
Further questions? let me know.
Sep 01, 2011 | HP Compaq nc6320 Notebook
Hi , my motherboard is k7n2 delta 2 platinum ms-6570e , i've had a problem to install windows xp , but finally i did it . Now i've got problem to install some programs like office , nero itp....
Hi, you can download the drivers manualy from here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Driver&os=XP%2032
The drivers or the bios file needs to be unziped before installation.
Install first the system and chipset drivers.
Try also to run windows update.
You will need the updates to install office and etc.
Try also to add more memory ( ram ) to your system.
Supports DDR200/266/333/400
Aug 24, 2011 | MSI K7N2 Delta2 Platinum Motherboard
Have an EVGA nForce 680i. Bought 2x 2 GB 6400 800Mhz of ram to replace 2x 1 GB sticks. However when I start up the system it only reads that I have 2874 MB of RAM. So I figured maybe one of the sticks is...
Hi.
The reason its only seeing just under 3GB of memory is no doubt because you are using a 32BIT operating system (probably XP).
If you were to install Win 7 (X32) or a 64BIT operating system the computer would see all 4GB of RAM you have installed.
Its nothing to worry about though as the computer will work just fine. If you were to check in the BIOS you would see all 4GB of memory is there and see by the BIOS.
Regards.
May 01, 2011 | Evga nForce 680i SLI (122CKNF68)...
Need BIOS update for my MX6424 Gateway with Win XP
If your board is not supporting the 2gb memory module, it won't make any difference by upgrading the BIOS.
Aug 27, 2009 | Gateway MX6424 Notebook
Acer 9300 bios upgrade failed
Hi!
I have the same problem, and my problem was that I have installed 4GB ram and that ram modules wasn't accepted with the new bios. So I installed the old modules and it all worked again, downgraded the bios to one version older and installed my 4GB ram modules and it all worked.
Hope that's your problem too.
Good luck
Feb 14, 2009 | Acer Aspire 9300 Notebook
Updating BIOS
You need to upgrade your bios.
Heres the link the software.
ftp://ftp.work.acer-euro.com/notebook/aspire_5630/bios/Bios%203.23.zip
You will need winzip or winrar to open the zip file just google either if you dont have them you can get them for free.
You then need to open the folder you just uncompressed and you will see another zip file, winflash is in there. it will allow you to flash the bios from within windows, just install it and follow the instructions on your screen
Dont forget to rate this solution
Aug 23, 2008 | Computers & Internet
Acer Extensa 4620 Notebook Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
