Question about Electrolux Centralux Vacuum
THE POWER HEAD IS NOT WORKING
The switch turns on and it does have suction but the roller in the head does not move and the light does not come on...Got any suggestions??
Thanks Shelly Hayes
  • Anonymous Apr 11, 2009
    same
  • 5 Answers
The fuse has tripped, press the red button on the top part of the head. It looks like an LED light, but its a trip switch.
Posted on Apr 15, 2009
My mat keeps moving around. Is there something wrong with the roller bar.
Your mat is moving around while you vacuum? It is probably because your vacuum has too much suction for that particular mat. Try adjusting the height setting of the roller head to be further away (less suction). That may help.
Nov 21, 2017 | Vacuums
Dyson Animal vertical portion won't lock into vertical position. However, all suction is going through the vertical portion...brush roller head isn't on at all.
Theres a part on the side that is free to move when u pull machine down for using it diverts suction.sometimes they get stuck pull handle right down to floor level turn machine over and check on the side at hinge part
Apr 15, 2017 | Dyson Vacuums
The rollers won't move and there is no suction. Any idea why?
If the rollers don't turn, the belt is likely broken or stretched. That shouldn't keep the suction from working though. Maybe clogged filter, full bag ?
Oct 29, 2015 | Vacuums
Dc 24 roller brush quit working....belt is okay & there are no obstructions on roller or in head compartment & suction at head is strong
Hi there, sometimes a stretched belt will hamper the vac. from picking up. he best way to test this is to turn the machine on, then carefully put you hand on the roller. If the belt is stretched the roller will stop turning when you apply pressure. Hope this helps, Chris
Feb 09, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Brush not moving, suction working
This machine is made for Sears by Panasonic. The power head, depending on model has a "gear" / cog belt or a standard flat rubber belt. First turn the power head over and see if the brush roller turns easily, if so you do need a new belt. To access the belt you will have to remove the hood from the power head. There are 4 screws, one at each of the corners to take out. Once the hood is off you will see where the belt goes and find "teeth" in the motor shaft for the motor / brush roller if you need a gear belt. If both of these are flat you need a rubber belt.
You can go to sears.com and find the belt you need with the vacuums model number.
Apr 27, 2010 | Kenmore 22812 Bagged Canister Vacuum
My Kirby Ultimate G does not have enough suction to pick up pet hair. Is there anyway this can be corrected? I felt under the vacuum when it was running, the roller is running, but I felt very little...
An Ultimate G has lots of suction. If you turn on your vacuum and the bag immediately inflates - that is how you can tell if your Kirby is moving air (suction). There is a more modern brush that came out with the Ultimate G Diamond and the Sentria that has stiffer bristles that dig up pet hair better.
Another way to test the suction is to spread some baking soda onto a hard floor and vacuum it up - you can see how much suction your Ultimate G has, or take off the vacuum head and put on a hose and test the suction at the end of the tube.
Ways to increase your Ultimate G cleaning efficiency. Take off the vacuum head and remove the brush roller. Attach your hose attachment and **** vacuum out the head. Put on a new belt, and remove any hair and or string or threads that may be wrapped around the brush roller. Put the roller back on and on the ends of your roller you will see that the ends spin and have numbers on them. If your vacuum brushroll is original - you could have your bristles rather worn and so you can align the #3 on BOTH sides of the brushroller. This would be a good time to consider upgrading to the Sentria Brush.
Remove the bag, and replace with the CLOTH Kirby bag. It has the best filtration and it has the best airflow (which increases what you are referring to as suction). If you want to go the cheap route - at least get the paper Micron Magic with HEPA filtration (but it has slightly less air flow)
Remove the side mini emptor from the vacuum and check to see if there is anything clogged up on either the vacuum or the mini-emptor.
If your engine is running and inflating the bag and you replace the belt, the brush roller and to the cloth dust bag - your vacuum should pretty much run like a brand new Sentria Vacuum. Your vacuum system is outstanding, but may benefit from a little TLC if you have been neglecting it.
Mar 19, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I have the A6000. It has power to the suction
If you have power in the wall and power where the cord enters the machine, you have a switch problem.
That is the approach I would follow.
Find replacement parts at a FixYa.com advertiser, your local appliance parts place or at www.repairclinic.com
thanks for your questiion
Please vote
thanks
Dec 13, 2009 | Vacuums
Eureka 4870: Brush roller turns even in hose setting.
You either have the wrong size belt, most likely too small, or you have installed a new belt incorrectly. When you open the cover on the bottom of your vac, you will see the pulley that moves as you flip the switch from floors to carpet. The belt does not go around this pulley. When activated(carpet) the pulley puts tension on the belt causing it to turn the roller. When switched back to hard floors, the belt looses tension allowing motor to cause suction but disabling roller. Also, the dial on top of vac is only to direct suction, not for disabling roller
Jun 21, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Roller brush will not move when vaccum is turned on
maybe the belt is broken. clean the unit and replace the belt.
May 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
May 03, 2009 | Dirt Devil SwivelGlide Bagged Upright...
Electrolux Centralux Vacuum Logo
200 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
