Question about Frigidaire FGR341AC Electric Dryer
Fridgidaire FGRB5700DS0 Only Certain Modes Produce Heat
Hi there, I have a two year old Frigidaire dryer model FBRB5700DS0. It has recently only begun to produce heat in the timed heat mode only. The automatic mode does not seem to produce heat at all. The lint trap in front is clear. Do I need to take the hose off in the back and have a look there? Any assistance would sure be appreciated!
  • caseywaymire Aug 14, 2008
    my dryer is producing no heat when i dry my clothes
    President:
  • 331 Answers
The control thermostat has failed. It's mounted to the plastic air duct that your lint trap slides into. You'll have to unplug the unit and remove the front panel to get to it. The part number is #131298400 and is available at a local appliance parts retailer. Cost is about $32.00.
Posted on Jul 29, 2007
SOURCE:
Dryer is turning but not getting hot
what's the brand name of the dryer and send the model number,if it's gas does the ignitor glow orange but no flame,also if it's gas when you start it you should hear a click,if you don't most likely the dryer is clogged with lint or the vent line is blocked with lint and the high heat popped the thermal fuse,but let me know what you have
Jan 24, 2014 | Frigidaire 134844410 Fridgidaire Dryer...
Frigidaire gas dryer, gallery series model GLGQ2152ESO - no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
Fridgidaire dryer model aeq7000eso isn't heating
Hi
Thanks for using FixYa. No Heat issue in an electric dryer is usually caused due to three things mainly: Thermal Fuse, Wiring Harness and/or Heating Element. Start with checking the Thermal Fuse which is mounted inside the back cover panel to the exhaust duct and is mounted in white plastic housing. If thats fine then the Heating Element should be checked. Please do revert for further assistance.
Thanks
Rylee
Mar 18, 2010 | Frigidaire AEQ7000ES Dryer
Fridgidaire fex831fs1 washer/dryer stack unit: how is washer timer function knob removed from timer shaft ?
i have a frigidare washer dryer combo model fex831fs approximately 6 mo old . turned on a load and water gushing out from underneath, checked hot and cold hoses not leaking, water coming from underneath
Mar 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
Hello, My gas dryer FRIGIDAIRE with model
check exhaust ducts and inside bad of machine for lint blockage over heat shuts down heat if not igniter or gas valve failure likely
Jul 06, 2009 | Dryers
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Fridgidaire Dryer runs constantly when plugged in
It has to do with the onboard timer or timer board
Feb 13, 2009 | Frigidaire FGQ1442ES Gas Dryer
Fridgidaire dyrer three years old
the heater has most likley shorted to yhe frame and needs to be replaced
Dec 23, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Fridgidaire GLET1041AS1
Unplug unit! Remove top screws and pull off top lid of dryer. Heater terminals should be at top right. Use ohm meter to check resistance. If ohms won't display, then your heater unit probably has an open circuit. For instance, my GLET1031 has a reading of 12.5 ohms.
Sep 30, 2008 | Frigidaire GLET1031 Top Load Stacked...
Frigidaire FGR341AC Electric Dryer Logo
131 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
