Question about Mitsubishi VS-60805 60" Rear Projection Television
Where can I get good E2PROM settings for Mitsubishi VS-60805?
My E2PROM on my Mitsubishi VS-60805 television was reset and I need to find someone with a working model who can give me their current settings, especially the deflection jungle. This would require accessing the service menu (which I can help you do, if you are a owner/non-serviceperson).
Please respond to this post and if you can help, we can exchange information then.
Thanks in advance for any assistance.
  • glennlray Feb 04, 2009
    There are instructions for accessing the Service menu starting around page 21 in the Service manual. You use the remote control plus numeric codes to view / change the settings.
    There are quite a few codes that would need to be reviewed, so if you're not familiar with accessing the menu, you may not want to get involved with this! :-)
    Problem Solver:
  • 5 Answers
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Posted on Feb 02, 2009
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Need to locate mitsubishi v 60805 manual. Thanks.
Here is a place that sells the manual. If you need help fixing it without a manual I would be happy to help you.
https://www.completeservicemanuals.com/mitsubishi/crt-projection-television/vs-60805-service-manual/prod_217.html
Depending on your problem a manual may or may not help you.
If this information helped you rate this solution as I do this here for free.
SD TECH
Jan 06, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
I have a VS 60805 and i need a Convergence Generator. They say these are no longer Available. Any Suggestions?
General Consensus is that Mitsubishi is a Piece of ****, has been for a long time and I was lucky that my Set worked as long as it did. I guess it is just another benefit of not have any national product in the US anymore. No matter I will never Buy Mitsubishi Again.
Jun 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Scrambled picture mitsubishi VS-60805
Hello deltamech,
Are you using your component video cables? if you are check to see if you are using the correct inputs. Look at the babck of your TV and see if the RGB (Lettering) matches with the box you are connecting to. What I am talking about is the YP(b)P(r) vs the YC(b)C(r) they are incompatable with each other.
Check that and if that is the case either match the two proper RGBs up or use another interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 25, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
Mitsubishi VS-60805 60" Rear Projection Television Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
