Question about Kirby G5 Bagged Upright Vacuum
G5 does not suck:)
Inherited this G5; mother-in-law said the motor was out. I plugged it in and it comes on, but it does not seem to be doing anything but turning the roller. It may just need a good cleaning. Plan to replace the bag and try it again; the drive part is not working, which ofr me is not the biggest deal - I just need it to vaccum the carpet. Kirby is a great vaccum and I really wantthis one to work for me.
  • 1,113 Answers
Re: G5 does not suck:)
You may be able to get it rebuilt for free!! Check the link below, also has a FAQ section for maintenance..........
Posted on Jul 29, 2007
Un-plugthe vacum andget a broom stick and slide it throuh the hose! it's clogged!and change the bag!
0 characters
3 Points
My Kirby is not sucking, seems to be blowing?
replace belt first. then make sure cloth bag blows up when switched on. if not then theirs a blockage,
Sep 25, 2013 | Kirby G5 Bagged Upright Vacuum
Kirby heritage vacuum
it's most likey it's the belt that needs replaceing witch is very tricky to do this video will give you full instructions how to change it.
Nov 10, 2012 | Vacuums
HI my mothers dyson, doesn't seem to be sucking up fluff that i could pick up, it does seem to pick up but not a lot.
look inside you will find other filters that are clogged .. often they are washable ... sometimes you have to replace them .. when they get clogged then pickup is not good and the motor can overheat
Oct 14, 2009 | Dyson DC14 All floors Bagless Upright...
Kirby g5 suction problem
If its not picking up as an upright but does with the hose, youve either not connected the belt or the belt is broken
Feb 17, 2009 | Kirby G5 Bagged Upright Vacuum
Just stopped working
mine has a reset on the power head. alittle red button the back. if it is that old and worn out i would buy a refurbished one on like think i saw one for around $350. just search filter queen and u will find them
Aug 20, 2008 | Filter Queen Majestic Canister Vacuum
Kirby blowing out aire
Unplug the vacuum and clean out the hose that goes from the beater to the intake. The hose is either plugged with debis or has become disconnected or BOTH. You may have to use a screw driver to remove the plate over the beater brush.
Mar 08, 2008 | Kirby G5 Bagged Upright Vacuum
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
had my steamvac spinscrub for 3 days now. it will not **** up why?
Jan 18, 2008 | Hoover F5906-900 Upright Steam Vacuum
Recently received a kirby from mother in law and don't how to change the belts
Dec 15, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5
nuetral/drive, the g series has a power drive motor for the back wheels
May 13, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
169 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
